Old 11-26-2019, 02:35 PM
mysticmissle's Avatar
charlie, do you have any pictures of your turbo set up? its currently a v8 or you are converting to a v8 from the 4?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
  #82
Old 11-26-2019, 05:36 PM
charlie66's Avatar
Im keeping the 4 cyl for now. I decided not to go 8 because it was cheaper to say with the 4.
But here are a couple of fab pics when i was making it ...
ID:	525472   Click image for larger version
ID:	525473   Click image for larger version
ID:	525474   Click image for larger version
My Half AN Injun.....
  #83
Old 11-30-2019, 10:10 AM
AIR RAM AIR RAM is offline
Thats honestly impressive at how close you where able to come to the frame without touching all the while keeping form and function. Impressive!
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
  #84
Old 11-30-2019, 05:20 PM
charlie66's Avatar
SPEED SAFE, NICK
It actually looks real close in the picture but its got like 3/8" clearance ..
Thanks for the props though..
These log headers work real well. I changed over from a real 1 7/8" tube header with 3 1/2" collector pushing 40 psi to this log and it made NO decrease in power what so ever.. These logs are also more universal for fitting different body/frame styles.. All you guys will be very happy with them if you ask me...
  #85
Old 11-30-2019, 07:20 PM
Finally received my Turbo manifolds and I am more than impressed with the quality of the welds and overall look... The ceramic coatings look amazing as well!!!
The only unfortunate part of receiving these is the fact that It will be well over a year before they get used.... Just like any build, it all comes together in the end.
SPEED SAFE, NICK
ID:	525731   Click image for larger version
  #86
Old 11-30-2019, 07:54 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Can we get a photo of inside the port area? Thanks
  #87
Old 11-30-2019, 08:34 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Looks great, awesome to see a bolt on, affordable V band for the Pontiacs. Would like to see any future GTO cross over for a single turbo and down pipe and the twin turbo down pipes.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
  #88
Old 11-30-2019, 08:37 PM
Sure,
These are the best I could get with the poor lighting I have around my home... I can take better pics tomorrow...
I honestly think they look great inside and out.
I have purchased shorty's and long tube headers from big name manufactures that honestly looked like crap... Gibson is the first one to come to mind...
SPEED SAFE, NICK
ID:	525742   Click image for larger version
  #89
Old 12-01-2019, 12:09 AM
73 TRANSAM 73 TRANSAM is offline
That looks very nice for the price. Also being a thick wall stainless, its not going to develop leaks like a SS tubular headers would. Almost bought one but I already have a complete system. Its going to be more turbo Pontiacs next year!!!
  #90
Old 12-02-2019, 03:36 PM
JSPONT's Avatar
Thanks, they look great! Wish they were around for d ports 6 years ago. That was the worst part of going turbo at the time.
  #91
Old 12-02-2019, 09:30 PM
Mark G Mark G is offline
cool
  #92
Old 12-03-2019, 09:42 AM
74SDformula's Avatar
74SDformula 74SDformula is offline
So has any determination been made if these manifolds will work with a serpentine system such as the March setup?
  #93
Old 12-09-2019, 10:27 AM
I have not yet... and it will be a long while before I find out (at least 1 year) however I do plan to run a serpentine system.
After talking with Steve with Stainless Header, he said he does not see any reason they would not. The end of the header is well behind the belt/accessory line. At that point you just clamp on what ever bend it is that you need to direct the exhaust to the desired Turbo mounting location.
So I honestly do not see an issue with a serpentine belt system.
Hopefully someone who has purchased these will be able to post some installed picks...
SPEED SAFE, NICK
  #94
Old 02-24-2020, 03:27 AM
R 70 Judge's Avatar
Just came across this thread. Has anyone confirmed if they fit a 2nd gen f-body? With E-heads or Highports? My brother has a ‘72 TA 455ho 4spd car he’s been working on for years. We already have a complete procharger blower set up with front mount air to air intercooler that’s already done, but it’s a smaller blower. Twin turbos would be a better choice.
Plus I’m currently looking for a ‘70 - ‘72 TA for myself. I’ll buy a set if they fit without issue.
Any input? Mock up pics?
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
  #95
Old 02-24-2020, 10:41 AM
ErikW's Avatar
ErikW ErikW is offline
I know they fit in a 76 fbody with the engine in the stock location (offset to the passenger side). Don't have mock up pics of that for proof. But we have to do a little clearancing of the frame for the driver's side to fit when centering the engine in the chassis.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
  #96
Old 02-25-2020, 03:00 PM
R 70 Judge's Avatar
Thanks for the info, Eric
James
1970 Trans Am
  #97
Old 04-07-2020, 12:05 PM
finished up a motor for a friend and had some time to mock these up on a 455. any front plate will require some creative thinking to get where you need to be. anything else should be fine. on the passenger side of a 455, under the #2 cylinder, there is a little casting kick out. this will have to be ground down to get the headers to bolt flush. i thik it is something the factory used for moving the engines into positon on the assembly line. Non issue for a turbo build, but it is a statement as to how tight these hug the block. I will fit them up on my IA2 in the next week or so.
ID:	536577   Click image for larger version
ID:	536578   Click image for larger version
1964 540 gto
  #98
Old 04-07-2020, 02:14 PM
ErikW's Avatar
Yeah, we're going to have to extend the driver's side log in our application
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #99
Old 01-17-2021, 12:03 AM
turbo69bird's Avatar
Anyone tried these in a first gen bird
960 HP @ 11 psi, 9.70 at 146.
  #100
Old 01-18-2021, 12:08 PM
I purchased mind for my 69 bird... I have not test fitted them as of yet. Still a ways away from doing so. But I honestly dont expect to have any issues. These hug the block pretty closely.
SPEED SAFE, NICK
