Anybody running a Crower 60243?
The cam I had custom ground for my 400 is pretty similar to the Crower 60243 cam, just with less lift and a bit shorter advertised duration. It will be this summer when I get it running, but I'm getting curious as to how it'll sound and behave. Plus I have 4.10 gears right now and I'm thinking that I'll want to swap to a numerically lower gear, but was thinking about how the cam would like it. Any of you guys have any experience with the 60243? Dyno #s? Timeslips?
73 Formula. 9.1:1 400 .030" over, TRW forged pistons, hand ported 6X-4s milled to 85cc, Ferrea 2.11/1.77, Crower 68404 springs, 276°/284° 228°/236° @.050 .474"/.474" 112 LSA, Performer RPM, Shaker Tuned Qjet, Hooker 1.75" headers. TH400, Hughes GM25 converter. 4.10 gear for now. 1st Drive: 12/30/16. *SOLD* 74 Trans Am 455 AT Buccaneer Red |
I have the 60243 in my '64 GTO's 9.5 to 1 462 with 3.42 gears and a 4spd. No dyno #'s or timeslips.
I'm very happy with it overall. Very streetable in a 462. Tons of torque. I'm looking to change to 3.08 gears. |
I ran the Crower 60243 in a 455 years ago. Pretty mild cam. No H/P or Torque numbers. I would estimate an honest 450 hp.
It sounded really nice with 2.5" dual exhaust with flow master mufflers. I will come off a light pretty good with 4:10 gear, but too much gear for top end.
Ken "Ace" Brewer put that cam in Jim Wangers Judge and we could be more happy. It has crisp throttle response and cruises the highway at 3400 rpm getting 14 mpg.
Dave "Big Injun" Anderson dave@4mypontiac.com www.4mypontiac.com For GTO Celebration items click the tile coaster. |
Compression ratio (heads and work),actual cam specs, likely will get you better comparables. Dyno # expectations will vary depending on the top end, from carb to final exit. Times just too many variables like total weight,rotating weight, heads, chassis, tune,traction,etc. To make a decent comparison, keep in mind you have a 400 not a 455+. |
.030" over 400, TRW/Speedpro 2262F forged pistons, .003" in the hole 9.44 SCR Mildly ported 6X-4 using Jim Hand's book, but not going as far as he did. He went to fitting a 1.69" valve down the intake throat, I went to a 1.66" in the throat. Milling, comp. valve job, 2.11" 1.77" Ferreas, Crower 68404 springs. Heads machine/blueprinted by Butler. Custom grind cam. Cam card attached. Magnum 1.52 roller tip rockers Hooker 1.75" 4 tube headers, Pypes 2.5" system with xpipe Shaker tuned Q-jet (thanks Jeff!) Port matched Performer intake for now, but will likely switch to an RPM or Crosswind DUI distributor, tailored advance curve. Will run vac adv as well Th400, TransGo shift kit, 2500rpm stall, 4.10 gear (for now), 25.6" tire diameter (for now) In a 73 Formula. Mild weight reduction, no AC. Probably around 3600lb with me in it, and that's guessing more on the heavy side. Won't be a daily driver. Just a fun weekend car that will see track time to get into the racing hobby. Not looking for a record breaker. Honestly if it runs a low 13 in the 1/4 I'll be ecstatic. Will run a radial at the track, probably a 28x10.5
If your springs and retainer to seal clearances will take it ( added .038" lift ) then running 1.65 rockers with the right push Rod will get you all the flow that your rework of the heads as made.
I may make that upgrade along the way. The only thing I may be worried about is piston to valve clearance since I'm using a .027" cometic head gasket to bump my compression. Was at 9.1 SCR with .041" gaskets. I'll be measuring my current clearance when checking rocker geometry. I think I'll be safe, but I definitely want to check. Any thoughts?
Something to consider
With your pistons .003" in and .027 gaskets, that gives you a quench distance of .030. Depending where/how the .003" # was measured on the pistons, ( hopefully that is consistent on all 8, and/or that is the lowest at the edge of piston) Piston to head(quench pad) is getting pretty close. When you fit things real tight, you better make sure everything is measured just right. Could end up an expensive testing of the boundaries. You'll likely turn it around 6k? Myself, I'd use a little thicker gasket... and give myself a little room. Sounds like a nice 400, don't read about many on here, everything is 455+. Factory rods? Curious on why the custom grind cam? Last edited by STEELCITYFIREBIRD; 02-15-2016 at 02:35 PM. |
