Old 03-18-2024, 09:34 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Scorpion and Harland Sharp rockers mix and match?
Need 3 new Harland Sharp 1.5 roller rockers - will the Scorpions set the pushrod in the same location = Length?
Thanks, Craig
Old 03-18-2024, 09:40 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
It should, for years I ran H/S 1.5 rockers on the exhaust side and PRW stainless 1.65 on the intake side and I used 9.300 on all 16 valves.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 03-19-2024, 05:45 AM
steve25 steve25 is online now
Yes it would , but I have concerns about the Scprions holding up for you if you have busted the Harland's which are stronger.
What's your open pressure?
Old 03-19-2024, 07:11 AM
ta man ta man is offline
Have you contacted Harland Sharp for replacement rockers?
Old 03-19-2024, 09:52 AM
78w72 78w72 is offline
Agree on contacting H/S, if you broke them they will probably warranty them, if not they sell them individually.
Old 03-19-2024, 10:25 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
HS can sell individuals as well as rebuild them. Nice folks to work with.
Also from what I have found every different brand even with the same listed ratio is slightly different, different pushrod cup depths, different roller wheel diameters.
Skip Fix
Old 03-19-2024, 10:26 AM
CraigG.'s Avatar
Thanks guys - just had some contact with the stud girdle and didn't want to run them.
They are back ordered.
Old 03-19-2024, 01:21 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Steve...I haven't used HS rockers for years, and I know they have some new options for Pontiacs since then. But I just picked up a set of Scorps Race series (vs. Endurance series) for my engine, and these are beefy and massive.....
Not wanting to argue, but rather curious as to why you claim the HS are stronger?
Name:	Image 3-15-24 at 1.56 AM.jpg
ID:	630625   Click image for larger version
Name:	Image 3-15-24 at 1.55 AM.jpg
Old 03-19-2024, 03:33 PM
Skip Fix's Avatar
HS has a "Race set" also really bigger and bulkier.
Skip Fix
Old 03-19-2024, 04:50 PM
grandam1979 grandam1979 is offline
I can honestly say a scorpion rocker is the only one I have seen split in half horizontally. I have replaced 2 sets for a buddy of mine with HS. From that 2 sets at least 6 of them started cracking and the one broke in half. This was not the race series rockers.
Old 03-23-2024, 09:35 AM
tc's Avatar
tc tc is offline
Craig, I have 1.65 ratio in HS and Scorpion. When setting up the rocker arm geometry, each brand required different pushrod lengths with the cam I have.
Also, the Scorpions measured 1.65 ratio with checker springs and 1.62 with running springs. The HS were 1.76-1.77 with checker springs and 1.65 ( maybe .01-.02 higher, don't remember ) running springs. I just use a small HFT cam, so no high spring pressures.
Hi Jim!
The Following User Says Thank You to tc For This Useful Post:
Old 03-24-2024, 01:23 AM
65 Lamnas's Avatar
Hi Jim!
Hey Tom! Been a minute or two..!!
Old 03-24-2024, 07:28 AM
chuckies76ta's Avatar
If your running a stud girdle make sure to run the 4 ends poly locks with the retaining snap ring. It prevents the girdle from moving down.
https://www.mvpmotorsports.com/comp-...d-studs/4508s1
Old 03-24-2024, 12:35 PM
CraigG.'s Avatar
Wow - I didn't know that could or did happen - I just thought it was my mistake.
Old 03-24-2024, 02:11 PM
Ya I had it happen and caught it right away. It put a few witness marks on the stud griddle. No damage. Just make sure you check the circumference of your poly locks so there all the same size. And also watch the size of the end that fits into the rocker for proper clearance. I run Crower 1.5 Stainless rockers and I used all the Comp cams polylocks. Seeing this happened make sure to check your pushrods to make sure that none are bent.
