#81
Cheers Jack,that's a compliment coming from you. I may fab another one for the big single turbo combo we're building for my sons race car (got to finish the 25.4 chassis first!), but I may modify it a bit to include triangulated side skirts and keep the side skirts inside of the oil pan rails this time.
#82
Glenn R. Lever Rochester, New York 14617-2012 Web Site http://www.leverfamilysite.com/ Front Engine Dragsters http://www.frontenginedragsters.org/forum/ |
#83
It is possible to add center counter weights to a forged crank if you really wanted to. But most go billet.
#84
Somebody (?) years ago added the center counterweights to the '61 SD forged crank in my hemi V8. They were more knowledgeable than me- the orientation of the weights isn't symmetrical as I intuitively would have expected. I haven't done the research to understand the staggered positioning of them, but the crank works great to 9,000 RPM. In a phone call to Mac McKellar I tried to follow his logic, but he lost me when he got into the math for 4th-order harmonic considerations...
#85
Glenn- back to your original question. Running 8 PSI boost now, I believe you could contest the 7.5 class without hurting your block. I ran a 401 c.i. iron blown-alky engine for 1 1/2 seasons at 12 PSI and 8,300 RPM without hurting the '67 2-bolt main block- didn't even hurt a main bearing. Obviously my 3.75" stroke was "friendlier" than your longer stroke, but your 4-bolt mains should help out.
#86
max hp stock block
There is a group on face book " Pure Pontiac power no prep outlaws" some guys making 700-800 plus N.A. horse power with stock blocks, they give some tips on how to make them live.
#87
There a plenty of turbo guys running more boost more horsepower than 800 for years with out any issues. They are all heavier cars than yours too. I think with the right parts and attention to details you will be fine.
#88
Im the admin of that page. Glad to know the group is getting out there!
1980 Trans Am - Street/Strip 462 Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas. Admin of Pure Pontiac Powered Outlaws on Facebook. |
#89
Another question along the same lines, this engine has no front support, with the crank be ok? (forged, nitrated, Eagle)
The new engine (the one to run 7.0 does have a front support). Glenn
#90
GTO George |
#91
8-71, stripped, new style Littlefield, it is still difficult to turn by hand.
Glenn
#92
Cool, I just sent a join request
1969 Pontiac Firebird |
#93
Great Page
#94
Its a good group!Plus all Pontiac engines!
#95
Do you have a link?
My Half AN Injun..... |
#96
#97
since the oem blocks crack from the mains to the cam tunnel I did a main spacer engine (dynoed 750+) build several years ago. The thinking was adding material will strengthen the known weak link in the block. This was done for a circle track application. This engine is in a s 10 drag and occasional parade pickup now. Engine getting tired now so, fixing to pull the engine/ take apart and check to see if there are any cracks developing.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
#99
J.C.- How were the split spacers held in location in the main bores? What wall thickness? Material?
#100
How would mains spacers strengthen the block in any way? Unless they were cast iron spacers welded in place and then line bored I can't see how they would add strength.
