Headlight Switch, Half Out Running Lights, Wire To Drop Hideaways?
I'm curious if it's possible to do this...
Running lights, half way out, 50% on headlight switch ..... Can the switch be tweaked to open the hideaways so you can see the headlights? I have Oracle LEDs and they have that cool outside ring when you're doing the running lights but on the hideaways you only drop them for main headlights, 100% out. I'd imagine there's a way to get the halfway pull out 50% in the switch to go full like the 100% out. Thanks Mike
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump, 12 Bolt, 3.73, 33 Spline |
Thread Tools | |
Display Modes | |
