big clunk help please
i just got my car driving again and it has no brakes yet, but when I put it in drive it makes a big clunk as if it just wants to take off, idle too high? and is it because i havent bled the breakes yet?
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
Idle too high?
I had same problem with a '74 400/th400. Had a shift kit which complicated things. fortunatly a wise old friend replaced my centrifugal weight springs on my HEI distributor and the problem went away. In fact I installed a MSD 6AL and was able to get this stock engine to Idle sooo smothly at 425 to 450rpm's that when i shifted into gear you could not hear of feel a thing. Increadable smoothness. people would come up and admire the car and then be shocked that it was running so smoothly and quietly. But Anyway... he replaced my agressive aftermarket centrifugal spring(s?) with some other combo and the problem went away. no other tuning was nessessarry. I'me still not sure on that one but It astounded me when I thought I knew it all. Bing,Bang Boom and it was all over. Done, fixed |
Could be the idle.............sounds like you may have a bad universal joint.
New u joints, new shaft. I have a points distributor.so is there a spring in one of these? and how do i replace it?
Check tranny fluid. Low level will cause that also.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
ok, how many quarts do u say it might need? its got a deep pan, and it had a empty TQ vert. ive put likt 5-6
Are you sure the driveshaft is the right length? after a tranny swap my car would clunk badly in and out of gear...turns out there simply wasnt enough of the tranny yoke sticking into the trans causing slop.
Vic in SoCal. Follow me on Instagram- Cloud9orbust 66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi. My T56 Install My Turbo Build My Vortech Supercharger Build Hyd Throw out bearing Misc Build Pics May the Karma Gods meet you half way.... |
well its in all the way it has a 6 in yoke i think.. so im sure its not that.
