Old 06-18-2014, 09:14 PM
cnc's Avatar
cnc cnc is offline
Default Dome aircleaner lid
Guys I'm looking for a Dome lid like this pic from Parts place
Its for the 70-76 Trans am Shaker set up...
Does anyone have dimensions on one of these lids...Thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 06-19-2014, 08:27 PM
74 SD455 Formula 74 SD455 Formula is offline
I have an original from a 76 T/A. It measure's 14 1/4" .
Old 06-19-2014, 08:53 PM
cnc's Avatar
cnc cnc is offline
Thanks 74 SD455 Formula..
Is it at all possible to get the dimensions of the dome that is the part i really need to know......
I need to know the dome height and the diameter if possible...I want to cut one up if its the right size dome I have seen them on Ebay and other vendors thanks for any help..Chris
Old 06-19-2014, 11:01 PM
Held for Ransom's Avatar
The '70-5 TA lid, as well as the '77-9 Olds 403 engine TA lid is approx. 13-1/4" wide (AC air filter A366C).
The '76-9 Pontiac engine TA lid is approx. 14-1/4" wide (AC air filter A542C).
Setting the lid on an air filter and taking the difference of the filter to ground and the top of lid (using a straight edge) to the ground is approx. 1".
Old 06-20-2014, 06:52 AM
cnc's Avatar
cnc cnc is offline
Thanks HFR I saw that the Olds one is close as well...all I'm interested in though is the dome dimension.....its gonna get cut up...Chris
