Old 03-22-2023, 12:30 AM
Jromaine87 Jromaine87 is offline
Default New Personal Best
After changing my underwear, I grabbed my time slip and I ran a 9.081 at 147.0
My previous personal best was 9.19 at 143. All I did was take off my wheelie bars and lower the launch from 5000 to 4600
I’m really dying to get in the 8s. I know the car is capable.
I know if I launch at 5000 now that my wheelie bars are not unloading my wheels, I can get it but I’m not sure I wanna stand it up more then what it’s doing now.
The Following 4 Users Say Thank You to Jromaine87 For This Useful Post:
Old 03-22-2023, 01:01 AM
Dragncar Dragncar is offline
1.23 60 foot, must have been a blast.
You have 8s in that thing, just keep doing what you are doing.
Going to need a parachute !
Old 03-22-2023, 04:13 AM
Scott Stoneburg's Avatar
Great job!!! Congrats on the new best!
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 03-22-2023, 05:00 AM
3X24SPD 3X24SPD is offline
HELL YEAH!!! NICE!!!
1966 GTO (Red) WARPATH
455CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
464CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
The Following User Says Thank You to 3X24SPD For This Useful Post:
Old 03-22-2023, 05:38 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Nice launch and car! Good luck gettin that 8!!!
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 03-22-2023, 05:56 AM
25stevem's Avatar
25stevem 25stevem is offline
Congrats to ya!
Your in a tuff spot I guess.
Since the idea is to go forwards faster and not necessarily waste time going up a lot hinges on if you do not need to rise up as far as you do, yet still get the needed level of weight transfer to maintain traction.
Then there's the consideration that if you go up higher on the start of a faster run you migh come down hard enough to hit the pan or your headers, andthen your fun day is over.
You need to talk to folks on here who are running faster then you, and when I use to wrench on a buddy's car we on,y got to a best of 9.13,
Keep plugging away and you'll get there and then be able to guide other folks where you where once in the dark.
I do stuff for reasons.
Old 03-22-2023, 05:57 AM
johnta1 johnta1 is online now
Congrats!
Nice launch.
What rear setup do you have?
Try adjusting the bars lower for less hit at the launch?
Old 03-22-2023, 06:52 AM
chuckies76ta's Avatar
Wow, Beautiful car. Care to tell us about your setup. specs. What converter? Thanks I would find a way to keep that front end on the ground.
Old 03-22-2023, 08:24 AM
Glad to hear the earlier upshift promoted a quicker time. Means (to me) you are working the Converter's TQ multiplier.
I think the sooner ya get into 3rd, and still on the Converter's TQ peak, the harder the acceleration from the HP. Power is Power, but gotta let it eat.
Great photos !
Old 03-22-2023, 08:32 AM
chiefbigb chiefbigb is online now
Find a good chassis shop around you and bring the car there for evaluation. They should be able to get you down the track with minimal front end lifting in the 1.18 range with those tires. Shocks and bar angle are critical
Old 03-22-2023, 10:02 AM
Scott65's Avatar
Scott65 Scott65 is offline
Yep^ Time for a bar/instant center adjustment.
Old 03-24-2023, 06:25 AM
gman005's Avatar
gman005 gman005 is offline
What is the race weight?
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 03-24-2023, 04:07 PM
Congrats!
Nice launch.
I have a 9 inch. I’ve played with the bars and taking them off resulted in a faster ET by a 10th.
The Following User Says Thank You to Jromaine87 For This Useful Post:
Old 03-24-2023, 06:29 PM
BILL BOWMAN1's Avatar
I believe he was referring to ladder bars or 4 link. Lowering the bar will soften the hit.
Old 03-24-2023, 10:40 PM
Is you car a 3 link ladder bar car. Or a 4 link car ?
Whatever it is, sweet ride for sure.
Old 03-25-2023, 07:57 AM
They are all the way to the lowest setting. It’s a ladder bar setup.
Old 03-25-2023, 07:04 PM
aaronman aaronman is offline
You don't want a chassis car launching like that. As stated by others you want to go forward and not up. Some pitch rotation is helpful but that's excessive and is going to end up causing you trouble long term. Tighten the front struts. Get the wheelie bars back on there and assure they are adjustable to the range required to settle down the front end. Get to a good track and test with someone who knows how to tune a chassis car suspension. As a last resort you can hang weight on the front end. I'm guessing there is another 1-2 hundredths to be found in your 60'.
Old 04-08-2023, 01:28 AM
I cut my rear bumper so I can raise the wheelie bars up some, also switched to 4.29 in the rear. Going to see how much it helps, my starting line ratio is 11.30 with the 4.56 , with the 4.29 it will be 10.60. I know it’s not much difference but it was a cheap option to try. Buddy let me use the gears to see what happens. I’ll get it figured out.
Old 04-08-2023, 11:01 AM
Will be interesting to find that the ET improves with 4.29s.
As if the Converter gets to TQ multiply more, and the Engine welcomes the increased load.
Old 04-13-2023, 05:45 PM
Probird's Avatar
Probird Probird is offline
Since the bars are in the bottom hole you are going to have to tighten up the front end or limit the front end travel. Limiting the travel makes a huge difference.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
The Following User Says Thank You to Probird For This Useful Post:
