Old 09-03-2023, 11:20 PM
jpg69bird jpg69bird is offline
Default 76 TA Air Cleaner Housing
The thermac is broken on my housing. Are there any other years that are the same as the 76, or is it a one year only design?
Stock 455, shaker, carb and intake.
ID:	619363   Click image for larger version
69 Firebird Conv, 350 HO w/3 on the tree swapped to Tremec 5 Speed - Sold
72 GP, 400 Auto - Sold
09 G8 GXP M6 Orig Owner - Sold
76 Trans Am 455, 4 Speed - Current
Old 09-04-2023, 02:09 AM
Trevor78 Trevor78 is offline
Most GM of the era used the same 2-3 setups for the hot air pre-heat. I'd have to check 1976 version of that aircleaner but likely same spotwelded flange that went around that hole that most had, coould take the foil flex pipe directly or use the plastic elbow. Some, like Corvette, used a steel elbow with dimples that pushed snug into a deeper section of pipe with two holes in it, same result.
Corvette type, would still work if diameter of pipe matches elbow adaptor or foil tubing.
Corvette 76 350 L48 aircleaner7 by Ben, on Flickr
Old 09-04-2023, 10:03 AM
burd's Avatar
burd burd is offline
That should be easy to fix
Saw plenty last weekend in Dayton, hit the swaps.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 09-05-2023, 10:07 AM
Thanks for the replies. When I hit the swaps, what other years are direct replacements? May not find one from a '76.
Old 09-05-2023, 10:24 AM
As per pics, pretty much eeeeeevery year that uses these types with carb.
