Pontiac - Street No question too basic here! |
View Poll Results: Which intake for this combo? | |||
P4B | 3 | 5.45% | |
Performer | 6 | 10.91% | |
Performer RPM | 19 | 34.55% | |
Holley Street Dominator | 4 | 7.27% | |
Torker 1 | 0 | 0% | |
Torker 2 | 6 | 10.91% | |
Other | 17 | 30.91% | |
Voters: 55. You may not vote on this poll |
Time to pick an intake
I'm just about done with the 400 to replace the destructo 469 and need to choose an intake. I have an idea on what I think it will like, but I want to see what you would run.
Here's the combo: 400 +.030 Lunati Voodoo 702 cam 9.76:1 SCR 8.26:1 DCR 16 heads Icon forged dish pistons Scat forged H-beam rods Factory crank Fitech EFI Going into a '67 Firebird with 3.54 gears and will see around 7000 miles per year. Use will be grocery getter, weekend cruiser, and maybe a trip to the track once or twice a year. ============================ Cam Style: Hydraulic flat tappet Basic Operating RPM Range: 1,300-5,500 Duration at 050 inch Lift: 219 int./227 exh. Advertised Duration: 262 int./268 exh. Valve Lift with Factory Rocker Arm Ratio: 0.468 int./0.489 exh. Lobe Separation (degrees): 112
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017 |
Stock intake would be fine.
Maybe jump over the performer and "try" an RPM. Would be nice if you cut you water crossover free so you can change plenums at will.
Carburetor building & modification services Servicing the Pontiac community over 20 years |
72 stock iron, nothing else needs to be considered!!!
68-72....
I'll agree a stock intake maybe an HO or a repop HO IF you get one without bad core shift-even them weld and port matching. They are a good 20 lbs lighter!
But since using the Fitech not sure how their spreadbore options are.
Stock..Ran a Performer and a Torker 1 ..Stock is the way to go..
1977 Trans Am,400 4 speed,numbers matching car 1979 Bonneville ,1 owner car... 1997 Trans Am convertible,LT1/auto. |
I agree with others, Stock 68-72 Iron would work great. If you are wanting to use aluminum, definitely jump over the "Performer", and use the "Performer RPM". If this is a street application, I wouldnt even consider the single plane manifolds.
1978 Trans Am Pump Gas 461 Stroker |
On such a mild build like that I'd run a stock intake. If you want aluminum I'd grab a repop HO/RAIV intake.
I've been daily driving and racing one of those for a couple years now on a 400 and can't discern any difference in performance at all between the two. |
And I'll suggest on this specific combo you wouldn't discern much difference on the street with a STOCK iron intake and a Edelbrock Performer intake. Providing both have ports that match OK to the heads in use. The Performer intake will be lighter.
Onward thru the fog. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-20-2020 at 08:15 PM. |
https://www.dapa.org/building-a-stro...ests/#more-106 Clay |
The Following 2 Users Say Thank You to "QUICK-SILVER" For This Useful Post: | ||
Holley Street Dominator or my favorite Warrior.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
How much more HP does it take to push that extra 25-30 lbs of cast iron intake.
From the 'fact or fiction file'....... "Even the lowly Edelbrock Performer consistently provides more low-end torque with stock D-port heads than any of the factory 4-bbl manifolds" Pete McCarthy Pontiac Enthusiast Magazine article, 1997 And here he was talking about a 400 not a 455 ! Even Cliff Ruggles stated that over the years he had a lot of smaller CID Pontiac engines that he was involved with that used Performer intakes, and they seem fine and none of them had any stumble, hesitation, ping or any other problems like he found with his KRE headed 455. Lets keep it apples-to-apples ! ! .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-20-2020 at 08:13 PM. |
The Following User Says Thank You to Steve C. For This Useful Post: | ||
I wonder if the FI Tech would prefer one over the other.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Some say it has issues on a dual plane intake. Others say that a notch cut in the divider helps. Other say only a single plane will work...
I've always ran a single plane intake with my Fitech so I don't have any first hand experience with any dual plane issues.
My vote is a factory intake OR a performer RPM if hood clearance is an issue. You won’t need a square bore to spread bore adapter with the performer rpm
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
The Fitech systems have been used successfully in both Dual Plane and Single Plane applications, but since the Fitech is a TBI system, and not a true "Port EFI" system, that injects fuel right into the valve, I still prefer the Dual Plane for a street application. We own two of the Fitech systems so far, both are used with superchargers. One is in a 1986 Trans Am, and is the 1200 PA Fitech system used as a "blowthrough" on a 383 sbc with AFR 195 heads and a D1SC Procharger pumping 14 psi boost. We use the Performer RPM Air-Gap intake on this application and works really well. The other is in a 1985 Chevrolet Long Bed C10 2wd pickup, and is the the 600 PA Fitech system used as a "drawthrough" on another 383 sbc with Brodix IK180 heads and a Magnuson M122 roots supercharger pumping 7 psi boost. For a "Port EFI" application, where the only thing that is being pulled through the manifold is the Air(not both Air/Fuel), I would no doubt prefer a Single Plane on all applications. Hopefully sometime in the near future, I will be converting the 750 Quick Fuel carb currently on my naturally aspirated 461 Pontiac, over to the 1200 Fitech, along with the addition of an 80mm billet BorgWarner S480 turbo.
FiTech or other TBI setup....I’m all for a Torker 2 or Holley intake on this debate
^^^What he said^^^
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
This is why i chose the Torker 2. also it's a good intake. with those rods/pistons and gears, no reason not to spin it.
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
Factory intake with a spread bore pattern Fitech, or if square bore Fitech use a Holley Street Dominator or Torker II
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Stock Iron intake
P4B Performer RPM We could agonize over which of these 3 Dual-Planes is better. I suggest "no difference" until there is a quantified evauation desired. Use whichever you have like. |
