#101
Thanks. Would have happened to run that sim high and maybe have 7000 and 7250 HP numbers? Stan
#102
677 @ 6750 663 @ 7000 652 @ 7250 All runs have been using "large open header" but nothing more specific. It has the power to tune for primary lengths, collector lengths and taper. Also stepped pipes. |
#103
Sorry I must not have highlighted this one. I wanted to see how it hung on after peak. Stan
#104
663 @ 6750 656 @ 7000 644 @ 7250 |
#105
I went back through my old emails, I remembered that incorrectly. Max rpm on that cam was 6500. Sorry for the confusion.
#106
I PM'd the OP the correct cam specs he should run for his application..... After five pages I felt he should get the right cam.
#107
Pasty Chef since this thread is about wide ports on a stock block, just curious what your sim would say about a set of standard ports. Just pick one of the cam mentioned here. For the heads just use a standard 330cfm e-head. Maybe the wide ports will be down on power??
#108
http://forums.maxperformanceinc.com/...3&postcount=60 Estimated CSA of the intake port? |
#109
Tested the smaller SD330 heads, used your .465 lobe shelf cam / same specs as before.
Avg 4500 to 6500 = 592 HP 655 @ 6500 651 @ 6750 639 @ 7000 ----------------------------------------------------------------------------------- For the 330 head, I asked it what events it wanted for best power 4500 to 6500 using .465 lobes. 1.65 rockers .020 lash 108 LSA / 105 IC Intake lobe 12604 294 267 194 .465 Exhaust lobe 12305 305 277 203 .465 Avg 4500 to 6500 = 601 656 @ 6250 660 @ 6500 652 @ 6750 |
#111
Interesting, thanks for your time and energy on this PastyChef. Maybe someday ill build a combo like this just to see how it does
