Old 08-11-2020, 07:23 PM
Stan Weiss's Avatar
Originally Posted by pastry_chef View Post
Intake 11468
Exhaust 11470
252 / 256 @ .050
111 LSA - 107.5 IC
Rockers 1.92 / 1.86 - .020 lash.
Peak 663 @ 6500 RPM - 663 @ 6750
4500 to 6500 avg = 595 HP.
Another metric 255 / 259 dur @ .050 valve lift.
For a few of the combinations I looked at duration @ .050 VALVE LIFT.
TMC cam 1 with 2.1 / 2.0 rockers = 269 / 271 dur @ .050 valve lift
Brian .465 lobe solid cam with 1.65 rockers .020 lash = 259 / 268 dur @ .050 valve lift.
New combo.
HXL 2231 intake, HXX 12203 exhaust.
270 / 274 @ .050 cam duration
108 LSA - 105 IC.
1.7 rockers - .020 lash.
Top performance so far.
Peak 684 @ 6500 RPM.
Avg 4500 to 6500 = 612 HP.
Duration @ .050 valve lift is also the highest - 270 / 274 dur @ .050 valve lift.
Mike,
Thanks. Would have happened to run that sim high and maybe have 7000 and 7250 HP numbers?
Stan
Pontiac Pump Gas List
  #102
Old 08-11-2020, 07:43 PM
pastry_chef's Avatar
Mike,
Stan
For the HXL / HXX lobes with 1.7 ratio.
677 @ 6750
663 @ 7000
652 @ 7250
All runs have been using "large open header" but nothing more specific.
It has the power to tune for primary lengths, collector lengths and taper. Also stepped pipes.
  #103
Old 08-11-2020, 07:53 PM
Stan Weiss's Avatar
Intake 11468
Exhaust 11470
252 / 256 @ .050
111 LSA - 107.5 IC
Mike,
Sorry I must not have highlighted this one. I wanted to see how it hung on after peak.
Stan
  #104
Old 08-11-2020, 08:38 PM
Mike,
Stan
Got it, this one was
663 @ 6750
656 @ 7000
644 @ 7250
  #105
Old 08-11-2020, 09:25 PM
Scott Stoneburg's Avatar
Originally Posted by Scott Stoneburg View Post
Thats what i was informed. Like I say i never tried it. My cam was 268/276 @ .050 with a .403 lobe. It made power to 6200-6500 I shifted at 6500. It didnt make crazy power, 550HP to the rear tires and went 10.20@ 131 in my 3500 lb street car.
I went back through my old emails, I remembered that incorrectly. Max rpm on that cam was 6500. Sorry for the confusion.
  #106
Old 08-11-2020, 09:53 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I PM'd the OP the correct cam specs he should run for his application..... After five pages I felt he should get the right cam.
Go fast, see Elvis!
  #107
Old 08-11-2020, 10:04 PM
slowbird's Avatar
slowbird slowbird is offline
Pasty Chef since this thread is about wide ports on a stock block, just curious what your sim would say about a set of standard ports. Just pick one of the cam mentioned here. For the heads just use a standard 330cfm e-head. Maybe the wide ports will be down on power??
  #108
Old 08-11-2020, 11:53 PM
I can check that tomorrow. I'll use the flow curves posted by AG here.
http://forums.maxperformanceinc.com/...3&postcount=60
Estimated CSA of the intake port?
  #109
Old 08-12-2020, 12:15 AM
slowbird's Avatar
Min csa is around 2.55-2.60
  #110
Old 08-12-2020, 09:36 PM
Tested the smaller SD330 heads, used your .465 lobe shelf cam / same specs as before.
Avg 4500 to 6500 = 592 HP
655 @ 6500
651 @ 6750
639 @ 7000
For the 330 head, I asked it what events it wanted for best power 4500 to 6500 using .465 lobes.
108 LSA / 105 IC
Intake lobe
12604 294 267 194 .465
Exhaust lobe
12305 305 277 203 .465
Avg 4500 to 6500 = 601
656 @ 6250
660 @ 6500
652 @ 6750
  #111
Old 08-12-2020, 09:59 PM
slowbird's Avatar
Interesting, thanks for your time and energy on this PastyChef. Maybe someday ill build a combo like this just to see how it does
