The cheap speaker may also be contributing to your undesirable experience. ...basically, you get what you pay for. |
if cars are anything like home stereo i have to agree with the above. cheap speakers as well as low wattage. i would get good speakers first and see what happens. if you need to keep that stereo get a cheap little amp at least 40W per channel. more enough believe me.
btw i got the speaker idea from the camaro site www.nastyz28.com and the pics are about 8 years old by now. so they may not even make that speaker number anymore, it could be outdated.
I no longer have that beautiful 66 in my Avatar. whaaa! When a cat is dropped it always lands on its feet. When buttered toast is dropped it always lands with the buttered side facing down. If a piece of buttered toast was attached to the back of a cat, when dropped, the cat/buttered toast combination should hover, spinning just above the ground, as it tries unsuccessfully to resolve the inevitable conflict of non-scientific certainties. |
I really don't know what the convector does but on all of the radios that have the A/M stereo 8-track tape player. It is located on my car up above the glove box & has 5 wires coming from it that plugs into the back of the radio. I think it is on all the radios that have the 8 track player.
Try a search in the 68-69 tech, This topic has been gone over many times.
Cuz68 |
I have a 69 GTO and I'm installing a non-stereo am/fm that has to be used with 8-10 ohm speaker. If I'm following this correctly I can use two 4 ohm speakers hooked up in series or two 8 ohm if I use a fader switch. Is that right? If so can I use a fader from a Chevelle? They are more available that Pontiac ones.
http://ultimategto.com/rest05cars1.htm |
Fader switch
Frank R-
If the picture you posted is a switch from the Chevelle I would think it would work, as it looks exactly like the fader switch out of my 69 GTO. I don't know this for sure, but if you already have it, I would try it out and see. I don't think it would hurt anything, it should either work or not.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
I did pickup the correct switch for my 69. I need to know the correct ohm speakers to use for my am/fm. It's rated for 8-10 ohm and if they should be wired in series or parallel.
Frank & the group:
The speaker needs to have an 8 or 10 ohm 'rating'...refer to my post #17 above. If you don't have speakers, you can get them from SM Electro-Tech (http://www.turnswitch.com/speakers.htm) - tell them that the RediRad Guys sent you. If you DO have speakers but they're crusty, you can have them re-coned for similar money. Good luck with it! |
So if I want to connect a 1971 factory radio expecting 8 ohms to a newer amplifier connected to 4 ohm speakers, can I splice in a four ohm resistor in series to get the nominally correct resistance? And that’s avoid frying my old radio.
PontiRocket |
PontiRocket |
Does anyone know where to get impedance matching transformer to take four ohm impedance amp to 8 ohms impedance?
PontiRocket |
You can put 2 4 ohm speakers in series.....just decide on placement.
You can also add a 4 ohm resistor in series....the resistor will dissipate the same power as the speaker tho. George
Does your amp use the radio's speaker output as input?
