Old 01-01-2021, 07:47 PM
jimib's Avatar
jimib jimib is offline
Default Legendary Front Seat Upholstery Coming Apart at the Seams: New Install
I am close to completing the upholstery on one front bucket seat bottom. I noticed a split in the seams in two areas as I was rolling the upholstery over the two front corners of the seats. In my opinion, this is the most difficult part of this project. I used the Legendary web site as a guide for this upholstery installation (https://www.legendaryautointeriors.c...lation-videos/). I replaced the broken springs with new ones, placed burlap over the springs, then a layer of cotton, then the ACI seat padding. I don’t think it is too thick. I’ll contact Legendary this Monday and hopefully they will give me a replacement. These splits can only get worse. If these splits are caused by my novice installation, then I will accept my losses and move on. I bought the Legendary upholstery and ACI foam for their known quality.
ID:	557353   Click image for larger version
ID:	557354   Click image for larger version
ID:	557355   Click image for larger version
ID:	557356   Click image for larger version
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
Old 01-01-2021, 09:12 PM
tempest1964's Avatar
This is not your fault. Defect in manufacture. I am sure Legendary will back their product. Keep us posted.
Old 01-01-2021, 09:45 PM
I had a similar experience with mine I did last year. Not as bad. But, I figured it was me and lived with it.
Old 01-01-2021, 10:54 PM
jimib's Avatar
Thank you "tempest1964", I feel a little better after reading your response. I'll certainly update this thread after I contact Legendary.
I wonder if this could be unique to this bottom seat vinyl stitching or a defective batch. If the latter, I can expect the same stitch separation with this seat's back vinyl cover and the passenger side bottom and back vinyl cover.
Old 01-02-2021, 01:33 AM
Judges4u Judges4u is offline
If the vinyl is cold, more risk of ripping. I use a heat gun to soften the vinyl portions that need stretching no matter what the ambient temperature is in your work area (summer or winter). The pre-heating really does the trick. When the vinyl cools down it shrinks back to the original size; the results are normal looking tight surfaces with no evidence of stretched seams or material. See pics
ID:	557375   Click image for larger version
ID:	557376   Click image for larger version
ID:	557377   Click image for larger version
ID:	557378   Click image for larger version
Old 01-02-2021, 01:50 AM
vertigto's Avatar
vertigto vertigto is offline
Interested to see how Legendary handles this, especially considering the 8 month wait I had to endure for my seat covers.
Old 01-02-2021, 01:55 AM
jimib's Avatar
I did use a basic hair dyer but I don't think it gets warm or hot enough.
Old 01-02-2021, 01:58 AM
jimib's Avatar
I'll keep you updated.
Old 01-03-2021, 08:53 AM
jimib's Avatar
I was working on the passenger side yesterday. Check out this separation at the stitching.
Old 01-03-2021, 11:22 AM
RFCOLEMAN RFCOLEMAN is offline
I have done only a few interiors, using Legendary Interior kits, but never had any issues like that. Something is definitely defective. But, I did have issues on the listings on the lower front seat bottoms on 71 T/A covers. I contacted Legendary, and sent then back. They took care of the issue promptly. I hate it when I run into an issue on a long weekend when you are counting on getting a lot of work done on your project. It causes way too much stress, and takes the fun out of it.
Any way, Keep us posted. I would be stunned if you do not get a quick reply and resolution from Legendary.
Bob C.
Old 01-03-2021, 05:32 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Did that happen from just rolling the seat cover onto the new foam? Wow, it doesn't look like that vinyl is very durable...
I have a set of Legendary seat covers sitting in boxes right now, I will have to look at them more closely and check the stitching.
Old 01-03-2021, 05:50 PM
jimib's Avatar
Bob C.
I received a reply today (Sunday) from the name "Lacy". Said would send to warranty dept but they are closed tomorrow (Monday).
Yes, this took up much of my limited time. Did Legendary send you replacements?
Old 01-03-2021, 06:03 PM
jimib's Avatar
Basically yes. After rolling over the two front corners, I pulled on the lower flaps of the seat to eliminate the wrinkles and getting ready to hog ring them, that's when I noticed the separation at the stitching.
I took someone's advice above and applied light heat with a heat gun to make them more playable.
Old 01-03-2021, 06:40 PM
dataway's Avatar
dataway dataway is offline
Curious myself since I have a set of front covers on order right now.
Makes me wonder if the long lead time is creating some shortcuts in QC ... or maybe some new people in training.
Old 01-05-2021, 11:13 AM
Yes. Legendary did send replacements after I returned the defective ones. I forget exactly how long it took, but it was fairly quick. They hade to make them. All of their products have a tag sewn in them with a date and persons initials on them.
That's how they can track them. I feel your frustration.
Bob C.
Old 01-05-2021, 12:56 PM
dataway's Avatar
jimi ... check for that tag on your covers and see who made them. Maybe we can spot a trend.
Old 01-05-2021, 05:10 PM
jimib's Avatar
I spoke with Legendary today and will say I don't like where this is going based on my predictions.
Around 12 noon, spoke with Ron and he said to forward him pictures. At 4 PM, no word back so again I called Legendary and transferred to Ron. He said based on what he can see via the pictures, it is an installation problem that caused the separation at the stitching. He said to ship them into Legendary. It's rather obvious where this is going.
Old 01-05-2021, 05:58 PM
dataway's Avatar
I'd guess if the stitch spacing is right, the thread isn't broken, the thread tension looks good and the seam is not stitched too close to the material edge they are going to call it operator error. Maybe a remote possibility of bad batch of vinyl, but they probably would have notice that during fabrication. A lot can go wrong sewing material like that, dull needles, machine out of time, tension adjustment faulty, stitch count set wrong, wrong thread used etc. Most of these things would be noticed on the first seam sewn.
But again, with the pressure they are under right now to get orders out anything can happen.
Old 01-05-2021, 06:14 PM
burd's Avatar
burd burd is offline
I would have taken them to a trim guy, the Jack of all trades doesn’t work.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 01-05-2021, 07:23 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
I always lay the covers in the sun to warm them up, assuming the area you are in isn't cold. Also cut to fit some portions of black trash bags on the corners/edges of the foam before pulling the seat edges/corners on. Then carefully pull the black trash bag pieces out. It makes getting the covers to slip around the corners much easier on you and the covers.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
