Old 03-08-2021, 02:50 PM
dataway's Avatar
dataway dataway is offline
Default Paint finishing order of operations
I've never been quite clear on the order of operations when it comes to the final buffing etc. of a new paint job.
What is the proper terminology for the products you need and in what order should they be used?
Cutting, buffing, polishing, etc.
Old 03-08-2021, 03:07 PM
dhutton dhutton is offline
I cut with Eagle yellow 1000, 1500,2000 dry on a 6” 3M dual action. Change disc at first sign of a pigtail. It’s shot at that point. Dry helps to see the peel and trash.
Then Trizact 3000 8000 wet
Buff with a black wool pad and ACA 3D 500 on a rotary
Polish with a chemical guys green foam pad and Menzerna 3 in 1 on a rotary.
Lots of ways to do this. This works for me.
If I have any wave I first block it with 600/800 on a hard block. Luckily this doesn’t happen often.
Eagle Tolecut blocks and precut sheets work great on runs.
Don
The Following User Says Thank You to dhutton For This Useful Post:
Old 03-08-2021, 05:31 PM
nytrainer's Avatar
Don are buying direct from a Eagle? Where do you find black wool pads? Is it a 3M double sided Pad? Thanks
Old 03-08-2021, 05:37 PM
I buy it from Eagle Guys.
https://eagleguys.com/
I use a Presta wool pad. This one because it interchanges with my foam pads.
https://www.ebay.com/itm/Presta-Blac...A/181927881992
Don
Old 03-08-2021, 08:10 PM
Don
Forgot to mention that I use an interface pad.
Don
Old 03-08-2021, 08:33 PM
nytrainer's Avatar
You using 7.5” pads on the rotary?
Old 03-08-2021, 10:46 PM
Yes. I have another small rotary that I run 3” foam pads on for tight spaces.
Don
