AC firewall template
Does anyone know where i can get some kind of template for the ac housings cutouts in the firewall for a 69 gto? Ive got a non air car that im going to be putting factory air back it and know i will need to cut out the holes for it as well as close up the holes from the heater box and was hoping someone sold/has a template i could layout. Ive looked online with no luck so far. Thanks!
I have done that to a 68 GTO. Can be done well, and i had the benefit of a real metal firewall for a template.
A stiff template may work very well. |
I went the other direction
Little know fact - the non ac firewall has a vertical rib stamped that the non ac doesn't have. |
Wanna try that again?
Greg Reid Palmetto, Georgia |
See the rib?
It's not there on an AC firewall. The stampings are different. Likely two different part numbers. |
Wonder if one of the "Vintage Air" type places could help you out. They probably know more about swapping AC components than most.
I think you still missed it...unless I'm missing it? Not important but read your first statement again closely. You said 'non' AC in both examples. No biggie, just joking around.
There are two different firewalls. The non AC has the rib The AC does not. Different stampings |
Yes, I got it from the initial post....I can't seem to get the joke across so I'll just let it go, not important at all.
I have a 69 that I am parting out thats factory air if you still need measurements
also I have all firewall parts in and out and ductwork and core dash pad NOT rusty . ... the ac is off the firewall now Scott Scott68gtoATcomcast.net |
Man scott, you're my hero lol. I dont know if you remember but i bought my hideaway headlight set up and my 4 speed set up off you. You're just the answer to any Pontiac problems i have. I would love some measurements from the firewall as ive failed to come up with them anywhere else.
I wonder if that driver side quarter window is any good....and if it's tinted..
yes its has tinted glass .....
but you would have a very big leak in your car when it rains ... the convert is about 4" short on the rear edge for your hardtop ... sorry Scott passenger side glass's have a couple scratches that are tough to see |
Didn't realize they were different...makes sense though since now that I think about it there is no c-pillar so I guess that would have to be a completely different shape. I know the door glass is the same.
Jeez, wish I had a yard as purty as Scott's.
Just for the record Greg, I got your joke. Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
The Following User Says Thank You to 4zpeed For This Useful Post: | ||
LoL
Im back
so it quit raining for an hour today and I snapped a few pictures and made you a template ... on the template that should read 1/2 " not 1/4" I trimmed the top to the shape of the cowl and tucked it over against the fender bracket ran afelt pen around the hole from inside and poked a nail thru the mount holes.... I suppose u can cut the big rectangle hole out of the cardboard with a utility knife then trace onto your firewall..cut to the outside of the black a tad because i traced thru the hole the heater core tube hole s may be tricky ... the mount stud holes ..... once you trim the card board big hole maybe lay the cardboard over your ac suitcase and do final adjustments ? pm me your mailing information and I will get it in the mail if its somethin you could use or any other tidbits ? Scott T |
Thats awesome scott, thanks again. PM sent.
??? no pm .........
Ok, ill try this again lol, pm sent.
