Old 07-12-2020, 12:36 PM
PontiacJim1959 PontiacJim1959 is offline
Default Doug Nash Plenum Dimensions
Tom V. asked me for the top plenum dimensions for the Doug Nash/Warrior Tunnel Ram Intake. I took photos and measurements for those who may want to know what they are. Have 32 pics and will add them down the line in separate posts due to space limitations. So, pics 1-5 here.
Pic 01 uses a tape measure for an actual height dimension. The photo with the ruler are all off by 1/16th of an inch due to the design of the ruler which has a 1/16th space between the edge and where the actual scale line increments start. I noted this on all the photos showing the height of the top section going from the highest point at the rear and tapering at an angle down to the front.
Pics 02-07 show the incline/drop from rear to front.
Pic 08 is the carb stud spacing on the side, ie linkage side of carb, approx 5 5/8" carb stud center-to-center. The side-to-side, ie front/back side of the carb, approximately 5 1/8" carb stud center-to-center measurement.
Pic 09 is the carb base width, side-to-side, 5 1/4"
Pics 10-14 show the distances from the carb plate holes to the side. They are not evenly centered by any means. I did not do the front, but they are no better. Diameter of the carb plate hole ranged from 1.67" to 1.69".
Pics 15-16 is the wall thickness on the bottom/base.
Pic 17 is the bottom plenum floor thickness, approx. 11/16"
Pic 18 is the rear carb plate, approx. 9/16"
Pic 19 is a side view showing the Balance Tube.
Pic 20 shows the distance from the base (which is level, not tapered) to the bottom of the tube, approx. 7/8"
Pic 21 shows the distance from the carb plate to the top of the tube, approx. 9/16"
Pic 22 is the carb stud spacing between front and rear carb base, 3 1/2"
Pics 23-25 is the balance tune length and OD dimensions.
Pics 26-32 are the interior of the top section. The bottom has the contoured diffuser in the center to direct airflow down into the ram tubes in pic #32. The top carb plate is just flat/smooth in the center on the under side.
Out of curiosity, I wanted to get an idea of how large the plenum volume was. I measured the rear carb mounting plenum as it is the largest. I blocked off the balance tube with clay and smoothed it to shape. I placed the top on a flat base sealed with vaseline and filled with a measured milliliter container until the water level touched the lower openings of the top carb plate. I held the plenum level to offset the built in taper. I did not fill in the holes at the base to make them level with the plenum chamber and included this area in with the overall final ML reading. The plenum held 825 ML, or 825 CC's. This converts to 50.35 cubic inches. Again, this is the larger rear plenum.
Name:	01 Rear-Rear Backside Actual Height.JPG
ID:	544814   Click image for larger version
Name:	02 Rear-Rear Carb -plus a 16th inch.JPG
ID:	544815   Click image for larger version
Name:	03 Rear-Side Carb -plus a 16th inch.JPG
ID:	544816   Click image for larger version
Name:	04 Rear-Front Carb - plus a 16th inch.JPG
ID:	544817   Click image for larger version
Name:	05 Front-Rear Carb - plus a 16th inch.JPG
Old 07-12-2020, 12:38 PM
Pics 6-10
Name:	06 Front-Front Carb - plus a 16th inch.JPG
ID:	544819   Click image for larger version
Name:	07 Front-Front Carb - plus a 16th inch.JPG
ID:	544820   Click image for larger version
Name:	08 Rear-Side Carb Stud Spacing.JPG
ID:	544821   Click image for larger version
Name:	09 Rear-Top Width.JPG
ID:	544822   Click image for larger version
Name:	10 Rear-Left Side Hole Spacing.JPG
Old 07-12-2020, 12:40 PM
Pics 11-15
Name:	11 Rear-Backside Hole Spacing.JPG
ID:	544824   Click image for larger version
Name:	12 Rear -Right Side Hole Spacing.JPG
ID:	544825   Click image for larger version
Name:	13 Rear - Frontside Hole Spacing.JPG
ID:	544826   Click image for larger version
Name:	14 Rear-Carb Hole Diameter.JPG
ID:	544827   Click image for larger version
Name:	15 Rear-Bottom Sidewall Thickness.JPG
Old 07-12-2020, 12:41 PM
Pics 16-20
Name:	16 Rear-Bottom Sidewall Thickness.JPG
ID:	544829   Click image for larger version
Name:	17 Rear-Bottom Plenum Floor Thickness.JPG
ID:	544830   Click image for larger version
Name:	18 Rear-Top Carb Plate Thickness.JPG
ID:	544831   Click image for larger version
Name:	19 Side View.JPG
ID:	544832   Click image for larger version
Name:	20  Balance Tube from Bottom Base.JPG
Old 07-12-2020, 12:42 PM
Pics 21-25
Name:	21 Balance Tube from Top Plate.JPG
ID:	544837   Click image for larger version
Name:	22 Mounting Hole Spacing of Carbs.JPG
ID:	544838   Click image for larger version
Name:	23 Balance Tube Length.JPG
ID:	544839   Click image for larger version
Name:	24 Balance Tube OD Width.JPG
ID:	544840   Click image for larger version
Name:	25 Balance Tube OD Thickness.JPG
Old 07-12-2020, 12:44 PM
Pics 26-30
Name:	26 Bottom Base.JPG
ID:	544842   Click image for larger version
Name:	27 Bottom looking in Balance Tube.JPG
ID:	544843   Click image for larger version
Name:	28 Bottom looking to Carb base.JPG
ID:	544844   Click image for larger version
Name:	29 Bottom looking to Carb base.JPG
ID:	544845   Click image for larger version
Name:	30 Top looking to Bottom base.JPG
Old 07-12-2020, 12:45 PM
Pics 31-32
Name:	31 Top looking into Bottom base.JPG
ID:	544847   Click image for larger version
Name:	32 Bottom base defuser.JPG
Old 07-12-2020, 04:40 PM
Tom Vaught's Avatar
Boost Engineer
Thanks Jim for posting that EXCELLENT information on the Doug Nash Plenum.
Tom V.
