Old 08-05-2020, 02:11 PM
Gary H's Avatar
Gary H Gary H is offline
Default Lower ball joint issue
I have a 62' Lemans race car with factory upper and lower A arms. The right lower ball joint, which presses in, is very loose and won't stay in. The ball joint itself doesn't seem to be worn out. Any ideas? I measured the opening in the A arm and it's 1.444". The ball joint measures the same
Old 08-05-2020, 02:53 PM
rohrt rohrt is offline
I just ran into the same issue. The only options are replace the arm or weld the BJ in.
Old 08-05-2020, 03:38 PM
Sirrotica's Avatar
Anytime you have an interference fit that is worn, you can use a prick punch on the surfaces of the parts to raise the surfaces over the OD and ID, and tighten the interference fit up. Since there is no downward force on the ball joint and it is always being pulled into the A arm while loaded, you really only need it to be tight as far as lateral movement within the A arm bore.
As has already been said. you can surely tack weld it in also, but if you have no access to a welder the raised surfaces from multiple dimples from driving a punch into the bore would also suffice to stop the lateral movement of the ball joint within the A frame bore. I doubt you'll be able to dimple the OD of the ball joint socket, as it should be hardened. Probably only be able to dimple the A arm bore.
If you were really ambitious you could weld up the A arm bore and then grind it back down to insure there was plenty of surface contact between the ball joint socket and A arm, pretty labor intensive, but probably the best way to recondition an obsolete part to like new specs.
Basically the owners choice of which repair they decide upon.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-05-2020, 04:35 PM
Gary H's Avatar
Thanks for the responses. I think what's causing the issue is when the car wheel stands on the launch, and then comes back down. The constant up and down movement has worn it out, A arms wise. At this point I think I'm going to pull the arm and weld the ball joint in.
Old 12-10-2020, 12:01 AM
pontiacbasics pontiacbasics is offline
Default Right side lower ball joint sheared off
The lower ball joint bolt broke off. I was lowering it off from a trailer and the car rolled down the ramp then the tire and spindle went under since the bolt had snapped. Do not know history of the car. Looked like original equipment.
Has this ever happened to anyone else
Old 12-11-2020, 12:22 AM
mechanickeith's Avatar
Have not had it happen to me with mine, but it sure could happen with any ball joint car. Time & wear from use is all it takes. Usually sped up by lack of lubrication.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
