Agree, very doable with a 400 and still very streetable. Plenty of engines smaller than that making over 500hp that make fine street engines.
Note this list is Pump Gas. http://www.magneticlynx.com/carfor/pont_gas.htm Stan
Your idea of a neck snapping 500 hp 400 and mine concidering the OPs 3,36 rear gears are 2 different things!
Combo is:
IAII A with a 4.320" bore x 4.21" stroke (Ohio crank 4340), 494 ci Crower forged rods/Ross pistons SD CNC heart chamber Eddy RP heads that flow 335 cfm 246/252 at 0.050", 0.400" lobe CC HR on a 112 LSA Northwind with an 850 cfm carb Have all the parts, just need to balance the rotating assembly and put together. Will run with a TH400, 3500 stall converter and a 3.07 rear gear in a '72 LeMans convertible.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
4.350 bore x 4.50 stroke = 535
Solid roller 296/304 @.020 260/267 @.050 4.210 lobe lift 112 LSA 10.42 SCR (would have to double check) 4L80e 3.73 No dyno time Thanks to Steve C on cam, spring, retainer selection. I think I would have gone 114 LSA and liked it a little more. Idles at 850 RPM, 11" vacuum, PB & A/C works as desired, drives easy, and becomes a monster with throttle. Pics attached, but most have seen already.... .
Sean 1967 GTO Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI |
535 cubic inches
4.5 stroke 4.350 bore 6.7 rods Edelbrock heads / 345 cfm at 0.600" lift 11:1 compression Torker II intake / 850 cfm carb Comp hydraulic roller cam P8 3318S/3319S HR112 248 / 254 at .050" 0.619" / 0.639" w/ 1.65 rockers 112 LSA 652 hp at 5400 rpm / 690 tq at 4400 rpm https://www.hotrod.com/articles/ccrp...-alloy-indian/ .
IA2 block
505 cubic inches 4.375 bore 4.210 Pontiac crank cut down to 3" main journals 6.625 BME alum rods Edelbrock heads- 315/240 cfm at 0.700" lift 10.5 :1 compression Victor intake / 1-inch cloverleaf spacer / 1195 cfm King Demon RS carb 2-inch headers Comp solid roller cam Lobes 4253 / 4214 276 / 284 at .050" .4400 / .4400 lobe lift / with 1.65 rockers 110 LSA / 107 ICL 742 HP at 6200-6400 rpm 670 TQ at 4900/5000 rpm Information from the "Road Warrior Build" Dec 2005 Hot Rod magazine .
500”
IA2 4.350 bore Crower billet 4.210 12.5:1 Highports 405cfm@.800 58cc Comp cams solid roller 50mm roller bearings In. .477 lobe lift 288@.050 Ex. .462 lobe lift 290@.050 110 lobe center T&D 1.8 ratio rockers Wenzler 2 tunnel ram with 2 850s Mcload dual 10” clutch Liberty 5100 5 speed Going in my ‘62 Cat Safari wagon Not sure on hp but I’m betting 800+ at around 7500 |
No dyno time, I kind of didn't care what the dyno numbers are.
E-heads, round port, Butler @320cfm type. The head flow is what probably holds it back some, 330s or 345s would have been better, but kind of didn't want to wait longer for them. .
78TA 400 stock bore and stroke #64 heads milled down .00045k= 9.3 cr Comp cam Thrumper, Tremec TKO5 ,stock 3.42 rear gears . dyno'd 360.1 hp probably a little more cam than needed but it sounds good
JIM |
66 GTO hardtop.
AGE M23 4 Speed 3.73 12 Bolt Rear / Eaton Posi, Moser 31 spline axles IAII - 535 Block KRE hi port heads / intake flow 360 CFM Scat Light Weight forged 4.5” crank Crower I-Beam Sportsman rods. Diamond forged aluminum pistons Approx 10.5:1 CR / 94 Pump Howards HR - 305/309 adv, 251/255 @0.50, 114/112 LSA/ICL,4/7 swap Johnson short travel HR lifters Holley EFI / FAST 4500 TB / Victor Intake MSD 6AL-2 programmable / MSD crank trigger 705 TQ @4500 / 699 HP @5600, 32 degrees total advance. We had to use a quick fuel 750 for the dyno (don’t ask) so probably left some on the table. Car is predominantly street driven. Vid/pic attached https://youtu.be/vz-l29omL70 Last edited by nmoreilly; 01-23-2021 at 11:57 AM. |
What do your heads flow? .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
be careful! |
The Following User Says Thank You to i82much For This Useful Post: | ||
360 CFM intake
#38
Just finished reading the thread on your 70 GTO - awesome! Open the heads up and the motor will be a monster!
#40
