#41
I helped my brother do some drivability tuning and experimenting on his dual quad hemi, and we found some interesting things. Based on those results, one thing I would be tempted to try with a cross ram, if possible, would be to run the carbs facing outward to the sides, and also with plenum dividers running the same direction. Looks like that would require a spacer/adapter. Makes me wish I had a cross ram to experiment with just for fun.
#42
#43
Can you install an oil cooler without a remote filter setup? |
#44
Yes, I had a transdapt cooler adapter that sandwiched between the oil filter and mount with npt ports to run lines to the cooler and back. I used it for about a week but found the oil temps never got over 180 and so removed it.
Still have the whole deal in a box around here somewhere if anyone is interested. |
#45
#46
I had a .060 over 455 with hard block up to the water pump holes. A low 12's car drove it on the street for years never had a cooling problem even in Arizona summers. I was running an aftermarket 4 row brass radiator called the desert cooler. I did not run an engine oil cooer they are in most cases a waste of time and money even for a drag car.
Tim Corcoran |
#47
Been running hard block to bottom of freeze plugs for 20+ years and won’t build an engine any other way, turbo engine at 960 Hp been together for 11 years now without a spark plug change, ( even won high performance Pontiac magazine day at ETown w it) running 9.70s at 146 good regular street beatings, still going strong doesn’t over heat ever, 2 bolt mains, stock cast crank, iron 6x heads. Typically 11 psi had it s high as 17 on the street.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
The Following User Says Thank You to turbo69bird For This Useful Post: | ||
