Old 01-17-2021, 07:47 PM
CraigG.'s Avatar
CraigG. CraigG. is online now
Default Water leaks on the back of a stock block?
Hey everybody,
Where do Leaks typically occur that roll backward to the transmission pan?
I can't seem to track it from the back side of the engine by the flexplate.
I have a stock block and E–heads.
Thanks again, Craig
Old 01-17-2021, 08:09 PM
tooski tooski is offline
I had a minor one that would leave a small puddle on the floor under one edge of the flexplate. Could not locate it until I crawled under the car before I shut the engine down after a good run. It was weeping a drop every few seconds or more. Dripping was gone when the engine cooled. It was coming from a frost plug. I added a bit of Barr's Leak (similar to the GM coolant leak pellets). Stopped the leak, but made the coolant look a bit 'dirty'.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 01-17-2021, 08:15 PM
ta man ta man is offline
Check your heater hose.
Old 01-17-2021, 08:21 PM
Freeze plug is the first thing I thought when I read the subject. If you can borrow a pressure tester, it'll show you right where it's coming from.
Old 01-17-2021, 08:22 PM
Tom Vaught's Avatar
Boost Engineer
Heater Hose and core plugs on the back of the block would be my first guess.
Do not believe E-heads have core plugs on the front and rear face of the heads like stock cast heads. I had a head core plug, rear of passenger head fail and cause the same dripping of water. Pulled the heads in a parking lot and changed the plugs in both heads in 1974.
Tom V.
Old 01-18-2021, 10:11 AM
78w72 78w72 is offline
Originally Posted by CraigG. View Post
Hey everybody,
Thanks again, Craig
check the heater hose threaded fitting/plug on the back of the heads, i had some very minor seepage there with the plug on drivers side, re did the thread sealer & tightened down the plug more & leak stopped.
Old 01-18-2021, 10:27 AM
Murf Murf is offline
From past experience, I would suggest not limiting your search to the rear of the motor. That stuff is sneaky and can travel undetected in some on the darnedest ways! DAHIK
Good luck!
Murf
Sent from my iPhone using Tapatalk Pro
Old 01-18-2021, 12:34 PM
sdbob sdbob is offline
Years ago a poor guy in our club had same problem. I went to help him. Jacking car up I crawled under to start loosening trans bolts. I reached and grabbed heater hose not leaking, started further loosening bolts, drip hit me. Yep the heater hose connection. I cut it off cleaned nipple no further leak. Might be cheap to replace hose clean fittings then see.
Old 01-18-2021, 02:39 PM
CraigG.'s Avatar
Thanks Guys for all the responses!
No heater here.
Keep your thoughts coming if have them - I'm always glad to learn more.
Take Care, Craig
Old 01-18-2021, 03:08 PM
steve25 steve25 is offline
My moneys on that side of the motor needing a new head gasket.
If so pull both heads and get them resurfaced to a mirror finish even if you have to travel a good distance to find an shop with hopefully a dimond cutter which would be the best!
Old 01-18-2021, 03:36 PM
lust4speed's Avatar
As mentioned above a few times, leaks can be sneaky and the engine not only has a tilt to the rear but the fan pushes everything to the back. A leaking intake manifold crossover gasket at the front will run down the valley pan and out the rear of the engine. Sometimes you get lucky and can spot a puddle on the flat where the distributor sits. Check the threaded plugs in top of the heads at the back where the heater nipple would have gone - surprising how the aluminum head and steel plug will start to leak months after initial tightening. The two big expansion plugs in the rear of the block could be likely suspects, and can also be looked at with a smaller inspection mirror between flexplate and block, but not easy.
Mick Batson
Old 01-20-2021, 09:34 PM
CraigG.'s Avatar
Thanks Guys - will report when work and family permits!
