Looking for a fine spline yoke to mate with a Super T10. I believe the TH400 yokes are the same.
Mark Las Cruces NM ___________________________ Current Project: '67 Catalina Convertible 400 4-spd |
Have one that came off a 67 turbo 400 driveshaft. Has 31 teeth, don't know part number. $25 plus shipping.
Let me verify spline count tonight. If correct then I'll take it. Thanks!
![]() ![]() Last edited by ROCKETMAN269V; 10-20-2008 at 08:55 AM. Reason: added info |
I won,t say that i am 100% correct but i think they are differant, i switched from 4 sp. to turbo 400, i had to change my yoke, i also have one up for sale for a Muncie style trans.
67 CRUISER
If you had a Muncie M20 or M21 4-speed, it would have a different yoke than a B-W Super T-10, which has the same spline as a T-400. |
or a 71 or newer Muncie
There are 2 different dia TH400 yokes...pre-69 it is 1 5/8......69-up... it is 1 7/8.
I assume you need a short TH400 yoke....there are also different length yokes. |
My spline count on the tranny is 32. I need to measure the shaft diameter now I guess...
I also assume I'll need the short yoke - but how do I tell? Car is currently an automatic, converting to 4-speed. I know the driveshaft is about 1" shorter for automatic cars than for 4-speed in a '64 A-body.
I think you need the short TH400 yoke...the sleeve is 3.5" long while the long yoke has a 5" sleeve. I attached a pic to show the difference.
SO, I have a couple of the short yokes and one long yoke. On the short yokes, some have slines all the way to the end and some start recessed in about 1/2 inch.
I do not know what year either of my TH400's are from. How do I know which yoke to use? On my race car, I am using a short yoke with slines to the end and it is out of the trans about 1.5 inches. On my street car, I am using a short yoke but with the splines recessed about 1/2 inch and with the yoke one inch out of the trans. Will the long yoke "bottom out" in the trans if its not the right yoke? I am very confused? How much is the optimum spline insertion for the yoke splines over the trans splines?
All of my cars are Hybrids...they burn gas and rubber! '73 Ventura, Spotts 462 roller 10.785 @ 122.79, 1.507 60 ft 2850 lbs. plus driver, 3150 race weight '69 Firebird Convertible, Spotts 455 with long branches 12.561 @ 107.62, best on old 455 4290 race weight '72 Formula 455 HO numbers matching auto, work in progress! |
Long yoke will bottom out.
I believe the ideal amount of yoke protrusion is approx 1". I think you need the short yoke with splines to the end. |
There were over a dozen different T-400 yokes used by GM from '65-79.
The T-400 yoke you're wanting is one of the medium length ones, the '67-71 GTO/Pontiac one, or the '72-75 version. Looks like several contributors are referring to this length of T-400 yoke as the "short" yoke. The short yoke is a different animal. Pull one out '76-79 Seville & see how truly short one is! |
