58/59 power brake question
What is the source of engine vacuum for '58 (and if it is different, '59) for the power brake booster? I need to know where the hose plugs into the engine.
Bill.....for the 59 Tri-Power it's at the rear base of the front carb. For the economy (small) 2bbl it's at the rear base. For the standard (large) 2bbl it's at the front base. For the 4bbl IDK......John
Thanks John. Is the "base" part of the carb? Reason I am asking is a friend with a '58 GMC with stock Pontiac V8 wants to add power brakes. The GMC enging uses the exact same part number intake manifold, but a Bendix/Stromberg carb instead of a 2GC. The manifold itself does not seem to have a provision for vacuum.
Bill.....power brakes need manifold vacuum. The base is the part of the carb that has the throttle blades, and should have a port that is below the blades. If the carb doesn't haven a tapped port there, you need to drill and tap the intake somewhere. Also a reserve tank with a check valve is needed incase the engine stalls......John
