wil the disc brake setup from a 68 chevelle work on a 68 lemans?
where would i get the calipers?? thanks in advance,just trying to help a relative out. |
Yes.
Pep Boys, etc. No Luck?? Try Master Power Brakes. Later--> ------------------ John
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
how about rotors
I tried opening a new thread to ask, but it doesn't work.
Oreilly was the last vendor I saw with rotors. Everyone else sells rotors and hubs. Does anyone know where I can get new rotors (only) for a 69 GTO? Also, is there some technical reason the vendors want to sell rotors with hubs? Hubs never wear out and they are heavy to ship.
~~~Dave~~~ Going too fast over the hill. |
My local auto parts store told me years ago that the reason they couldn't get two part rotors was because of safety reasons. I know, I know, lots of cars have seperate rotors, just what they told me. The single piece rotors work just fine an are availible everywhere so probably will just have to convert, or find some meaty originals! Scott
Inline tube also has the rotors - they are a 1 piece but work all the same. |
Carquest / NAPA can get the calipers/ hoses/ ect. They aren't cheap.
69 rotors are a bolt on. Mike
I have a complete disc brake conversion from a '69 (single piston calipers). Includes spindles, calipers, master cylinder, new pads, proportioning valve, upper and lower control arms, etc.
Give me a call. Tony (231) 937-4113 |
Incorrect. The 1967 - 1968 Disc brakes were 4-piston calipers each, similar to the Corvette design, only larger. They tended to corrode and leak past the individual piston seals with the original cast iron calipers. Current fix is to have stainless steel sleeves installed. I have two cars with them and two sets as spares. When they are maintained correctly, they are AWESOME and generate much greater clamping force than a standard 69+ replacement.
then why did GM spend hundreds of hours and tons of money to develope the single piston caliper that was used from 69-into the 80's - If the dual piston was so great they would not of discontinued it. - it had its run as the first attempt at disc brakes and they found a better solution.
Thanks for the correction - Since the caliper is 2 pieces and have 2 pistions on each half it does have a total of 4 pistions or Dual Piston pushing points - any way you slice it -I think people get the picture it is not the single piston design. I did not want to get into such tech detail but since you brought it up the Pontiac, Buick and Olds, dual pistion are a slight bit different from the Chevy A-body - The bore size is different - but it would fit the same and not make any bit of difference - not noticable anyways. You can buy the new caliper and it has the delco markings and it is at your door in a few days or find a place that still rebuilds the old rusty stuff and take your chances and have the car down for a few weeks. Make sure the place you choose rebuilds your actual calipers - Sometimes they just use yours as a core and you could get one back that are far worst than you sent. The bigger brake companys do not offer the service any more - Master power and Stainless Steel Brakes do not offer it any longer but i hear white post still does them. |
Actually, when the 67/8 set up works it stops better than the 69-72 units. The stainless resleeving is a viable option but is $$$$$$$$$$ compared to the later units.
Cost is why GM retooled. The single calipers are cheaper. Mike
I do not agree since the 67-68 had much smaller pistons and the 69 had one large the piston in the 69 is about the same if not more than the surface area of the smaller pistons. The rotor was the same and the valve was changed for 69 for the new caliper design to achieve the same stopping distance as the year before.
The 67-68 had problems from the start with the pistion and metal casting. Stainless Steel Brakes Corp. Started as a Rebuilding Company in 1977 to help solve the problems with the calipers on the corvettes and soon was doing all the dual piston caliper rebuilding. |
Guys, my "argument" is from the technical definition meaning discussing views. Here is some information that will help understand the good/bad of these designs. Remember, the decisions made are not always based on mechanical performance, but on financial performance (accountants) when considering maintenance/warranty costs, costs of manufacture, ease in bleeding system, etc.
Advantages4-piston design AdvantagesIf you take note of all of the current high-performance automotive braking offerings from manufacturers, they are all using fixed, multiple piston design for superior performance. The introduction of better machining and the use of aluminum has greatly improved this design. |
