Old 01-26-2007, 04:25 PM
'69ragr's Avatar
'69ragr '69ragr is offline
Default New Gauges
Has anyone installed new aftermarket gauges in the dash (inplace of stock speedo etc.) of a 1969 GTO. Any ideas or direction/parts being used would be appreciated.
Thanks.
Old 01-26-2007, 07:45 PM
gto4evr gto4evr is offline
Just curious why you'd want to replace the stock speedometer for an aftermarket one? if it's due to it not working, you can pick up stock non-rally clusters all day long for $15 off ebay or 1/2 the members on this board.
Old 01-26-2007, 08:53 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
I installed an autometer speedo and tach in my 68 GTO. Cut them out of the cans then fabed bracket to fit in the stock dash.
TigerEFI.com (Classic Pontiac Fuel Injection)
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
Old 01-27-2007, 12:36 PM
'69ragr's Avatar
Thanks guys. I wanted to put in a tach instead of the clock so I was going to upgrade the speedo. I was of the opinion that quality guage manufactures such as Auto Meter and Sun were much better that the repops for tachs and speedos. My experience with a repop hood tach was not a good one.
Old 01-27-2007, 12:52 PM
Jack,
curious how you put that speedo in, did you gut out the original to leave the turn signal lamps in place? I can't be sure but is that a rally cluster with gauges instead of the lights? Nice modification, a trip meter in a GTO!
69ragr, I don't think they're repopping speedo's but maybe I'm wrong, but as I said, they're cheap and easily available (I'm sure I have a couple in the piles out in the shed)
Old 01-27-2007, 02:23 PM
robz's Avatar
robz robz is offline
gto4evr, Jack seems to have a 68 GTO (from pic), which had the turn signal indicators on the dash, rather than in Speedo face
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
Old 01-27-2007, 03:13 PM
rob,
the 68 indicator lights were still mounted on the cluster. There were long plastic tubes that tunneled the light from the cluster out to the dash.
Old 01-28-2007, 10:37 AM
robz's Avatar
I see..thanx. Wouldn't that still be fucntional then unless he dismantled the actual cluster casing? Installing speedo shouldn't affect it..
Robert
1969 Grand Prix SJ
Old 01-28-2007, 10:55 AM
MORTIMER MORTIMER is offline
Default Here is a set of 68 gauges for an example.
I have these for sale on the EBAY. However as an example for this thread, here are some pics.
Mortimer
Name:	68 guages 1.jpg
ID:	80751   Click image for larger version
Name:	68 guages 2.jpg
ID:	80752   Click image for larger version
Name:	68 guages 3.jpg
Old 01-28-2007, 11:10 AM
It's been a looooong time since I played with a 68. Thanks Mortimer -- THAT's it!
