Industry Stuff new repro's, updates, other info.
Old 09-06-2019, 08:27 AM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default Voltage Regulator Rebuilding
Does anyone know of a rebuilder for GM voltage regulators?
Have a April 70 dated reg and it stopped working driving back from a show last weekend.
Tried filing the points but still not working.
Thanks KC.
Old 09-06-2019, 10:35 AM
OG68 OG68 is online now
Ebay vendors sell a electronic conversion kit using the frame of the original regulator.
https://www.ebay.com/itm/1963-70-PON...dZ1-Zx&vxp=mtr
https://www.ebay.com/itm/Delco-Solid...1Z~NV~&vxp=mtr
2007 Cadillac SRX
Old 09-06-2019, 06:23 PM
Default Regulator
Thank You
Old 09-06-2019, 07:01 PM
indymanjoe's Avatar
do you have any starter, alternator rebuilder's near you? just throwing that out here.
Old 09-06-2019, 08:01 PM
Default reg
I tried that, called a couple of places yesterday and no luck.
Thanks KC
Old 09-06-2019, 09:40 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
This gentleman repaired an OEM GTO voltage regulator for me in 2015.
John Pirkle Jr.
1-706-799-7025
Good Luck.
Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 09-07-2019, 08:00 AM
Default Reg
John Pirkle Jr.
1-706-799-7025
Good Luck.
Chris.
I have used them before, had good luck with alternators when Sr was alive but not so much with Jr. I heard he stopped the resto business he took over from Sr but I will call him. Thanks KC
Old 09-07-2019, 09:23 AM
Boiler Boiler is offline
It's my understanding Jr sold the business.
See this thread from the Corvette world on how to take the guts from a Wells VR-715 ($35 at AutoZone) and install them in the original Delco VR case.
https://www.corvetteforum.com/forums...r-rebuild.html
or just buy a solid state kit: https://www.zip-corvette.com/63-68-v...onversion.html
I would go with the VR-715 guts. It's all surface mounted devices vs. the capacitor on the kit version which is through hole.
Old 09-07-2019, 05:56 PM
Default Reg
Excellent
Thank You
KC
Old 09-16-2019, 03:06 PM
GT182's Avatar
GT182 GT182 is offline
KC, how about putting in an internal regulated alternator and by passing the stock regulator, but leaving the original on the firewall? I did that with my 66 GTO and have never looked back. You can gut the original and use 2 jumper wires on the inside of the connector blades. It will look like you're still using it. Wire jump 1 and 3, and then 2 and 4. Connect the alt regulator wires to the original wire set to the regulator and you're good to go. I can get you photos if you need them.
No more problems with the one on the firewall, and it will save money in the long run.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 09-17-2019, 09:09 AM
Default Reg
Thanks for the info Gary.
Old 09-17-2019, 03:41 PM
GT182's Avatar
No problem AC. If you want, I can post a photo of the jumper wires in the regulator... which is gutted. It's still on the firewall tho.... just for looks.
Check this post as it shows everything with more info from Wallace Racing. The regulator isn't shown but the jumper wires are.
http://forums.maxperformanceinc.com/...13#post3417813
I can still get you the photo of mine just to make it clearer where the jumpers are soldered to the prongs of the regulator.
Gary
Old 09-19-2019, 07:52 AM
Default reg
[QUOTE=GT182;6062903]No problem AC. If you want, I can post a photo of the jumper wires in the regulator... which is gutted. It's still on the firewall tho.... just for looks.
I can still get you the photo of mine just to make it clearer where the jumpers are soldered to the prongs of the regulator.[/QUOTE
Sure, Thanks
Old 09-21-2019, 08:17 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
I am so thankful our forum is light hearted. I opened the link to read about the conversion & all of the sudden everyone was arguing. Geeez, was a little irritating to read. While I have owned a couple of C4's years back, I am glad I am not in that vette scene It's different kind of car world.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 03-31-2023, 08:35 AM
brad01 brad01 is offline
I still have the stock external regulator on my 69 gto with stock alternator. I did notice it was overcharging a bit last Summer so I made a regulator adjustment. Whats the benefit to going to this product?
Old 05-25-2023, 10:22 AM
68bird400HO's Avatar
After trying to clean the contacts and play with the adjustments without success, I bought the USA made solid state conversion kit and did it myself. It was pretty easy.
