#41
I did this for years. It was awesome. Clear coated spiral cable with aluminum figure 8 “ crimps”. Got the whole thing at the good hardware store. Had just enough flex but locked solid on a 500hp sbc. Never saw any slip in the crimps
GOD does business with people that mean business! |
#42
Use a smooth idling cam, the car will be more fun on the street and usually faster..
#43
I put in a Riv Nut in the frame and now I'm looking for a spot on the motor to tie to. There is one open spot on the head behind the power steering pump. Its pretty tights so I'm not sure it will work. I was also looking at the head bolt or exhaust bolt as an option. I also noticed I have an open motor mount bolt hole, but you mention "2-Bolt Blocks are not too strong in the pan rail area/mount area" Not sure I'm interpreting your meaning correctly or not. This is a 455 block with the 5 mounting holes. Its in a 68 bird so I'm only using two mounting points. This open mounting hole looks like a perfect spot. |
#44
Go for it.
#45
Are there any pics of the plastic coated wire strap arrangement please. I would be interested to see how this has been done for my 600HP street/ strip firebird.
#46
Old thread I know, but I've run the chain from the cylinder head to the frame rail on a couple cars. My 87 GN currently has one, and it definitely does its job.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
#47
I thought I might need some type of torque strap for my motor, but I used these Butler mounts and I have virtually no movement of my motor regardless of condition (idle, WOT, hard shifts). They are almost like a solid mount. Still no transmitted vibration either. I'm pretty happy with them. Not a good option if your motor is already in your car, but if you have your motor out, it's something to consider.
https://butlerperformance.com/i-3164...tegory:1393551
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
Thread Tools | |
Display Modes | |
