3/8 pushrods
Is it worth stepping up to a 3/8 pushrod on a roller cam/valvetrain? What is all necessary to make them fit and clear without issues? Will be going in the 432 with edelbrock round port heads I’m in the process of building. I was looking at the Smith Bros 3/8x.120 pushrods from Butler.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
hyd or solid?Tom
Doubt you will need them.I have a engine going together right now with 160 on the seats and we are using 11/32 because that is what the guide plates are.I have used heavy wall 5/16 Smith Brothers with 200 on seats before with no issue.FWIW,Tom
I’d still be curious as to what would be necessary to run them. While I doubt they’d be necessary it doesn’t sound like it’d be a bad upgrade to prevent any pushrod deflection.
Depends what heads and rocker the actions and guide plates.Tom
Rocker ratio!
Edelbrock round port heads and Harland sharp 1.65 full roller rocker arms.
IMO, you're throwing extra weight into the valve train for nothing (so far as I have read) that 5/16 .116 wall size Smith Brothers pushrods couldn't easily handle.
What size is the cam and are you bracing the lifter valley too?
Only a pawn in game of life. |
243/251 @.050 and .618/.622 lift. Yes im bracing the lifter bores. Its my understanding that the weight between the camshaft and the rocker arm has minimal effect on anything and is a better tradeoff to have a stronger/more stable valvetrain.
You also dont need the lifter brace with that small of cam.Tom
I'm building the engine now. I'd rather over build it once and be done
No need for 3/8" pushrods for a HR cam. You would have to find or make or modify some guide plates to do it. They would need a 5/16" balls and undercut rocker tip end. Also probably need to grind more clearance into heads.
