An engineer went to get new tires put on his car and was standing there watching the young man mount and balance the tires. While he was working the young man said "...do you know why I put some of the weights on the front side and some on the back side?" The engineer puffed up a bit and said "well...actually...I do. If you put them all on one side then it can allow the imbalance force to create a moment arm with a force vector in proportion to the wheel offset; if that is not resolved then it can result in a dynamic oscillation at freeway speeds." The young man blinked a few times and said "yeah, cause if I don't it'll wobble". K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
LOL
I love nerd humor. Note the location of the bank ... guy was a Nuke.
I've had better success with old school bubble balancers. You can get them pretty much perfect with that, but not with a spin balancer. They have tolerance ranges.
Small wheels (13's-14's) will have issues if off 1/4oz., low profile tires will have issues if off 1oz., 15's and up with normal height sidewall is much more forgiving. I bubble balanced those 4 - 17" Chrysler wheels in 15 minutes using tape-on weights. No way could I have done them that quick with a spin balancer which is why my spin balancer doesn't see much work.
Also, if you are going to use a spin balancer, it is best to use the lug mount adaptor and mount the wheel via the lugs. This is mainly for aluminum wheels. Steel wheels don't matter. |
honeycombs are steel wheels & require the lug centric adapter to spin balance properly.
I also have a balancer that does it with the wheels on the car, balances the rotors and drums and all.....
So if you have a problem child this machine gets it done. |
Yep, that's because the center part that the cone would usually center the wheel with is made of the urethane with a small metal sleeve trapped within it and actually isn't part of the steel wheel itself.
I knew I should have stated "standard" steel wheels.
True but almost useless on the drive wheels though.
Works on all wheels, front and back.
How are you going to obtain a proper wheel balance on a posi rear wheel or a FWD front wheel? The harmonics that transfers through the drivetrain makes it almost impossible. This is why shops stopped using them and they became obsolete.
That's the whole purpose of them, to balance everything that is rotating. They actually work really well with practice.
They are probably seldom seen these days for a number of reasons. Techs with lack of knowledge on how to use them, and I'd bet OSHA these days has a spaz attack when they see one, with all the safety hazards these things present LOL Probably raises the insurance rates at the shop You can get that wheel going 100 mph, and if the tread has pebbles in it, it'll put an eye out, and you don't want to stick a finger in there or you'll pull back a bloody stump. LOL |
We'll have to agree to disagree on the drive wheel balance but I have heard my fair share of rocks hitting a wall. LOL!
And yes, dumbasses with smart phones couldn't operate a Hunter Head balancer if their life depended on it. |
So now people with a phone that isn't 20 years old are dumbasses? Jeez, this went off the rails.
Trust me, it relates.
In an aside, roughly 30 years ago I bought tires from a guy with a small shop. Before he actually balanced the tire, he put the "common steel wheel" on the bubble balancer, noted the heavy side of the wheel and marked it. He did the same with the tire to find the heavy side of it. Then when he mounted the tire on the wheel. he put the heavy sides of the tire and wheel opposite each other. After the tire was on the wheel, he then balanced the whole assembly. He told me that procedure minimized the number of weights he had to use to balance the tire/wheel assembly with lighter weights generally being the only ones required and gave a better balance. After he retired not long after this, I used regular local tire places who chuckled and said he was nuts to do this, the dynamic balancer would solve all imbalances.. I still think the old guy had a method to his "madness". If I had a bubble balancer, I think I would probably try this method.
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
#38
At one time the hole for the valve stem was drilled on the heaviest side of the wheel and the tire had a mark on the lightest side of the tire . So we told our students to line the mark on the tire with the hole for the valve stem. That way you would use fewer weights to balance the wheel assembly. I didn't know if the tires are still that way or not. I know tire busters just mount tires as fast as they can now and use computerized balancers.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
#39
If the assembly is way out, then break the beads down and rotate the tire on the rim 180 degrees. Usually it will balance up after that. K
#40
i took the M/T tires to be mounted at a local family owned shop i use & asked the guy, who is somewhat of a car guy, about the marking & positioning it at the valve stem hole, he said he doesnt bother with that these days since tires are so inconsistent, said hes done it lined up & not lined up & the results are always different. funny thing is when i got them home & looked at the weights, one of the tires was just a bout lined up with the mark by chance, & sure enough its got more weights than the one that was not any where near lined up. |
