#41
I did this for years. It was awesome. Clear coated spiral cable with aluminum figure 8 “ crimps”. Got the whole thing at the good hardware store. Had just enough flex but locked solid on a 500hp sbc. Never saw any slip in the crimps
GOD does business with people that mean business! |
#42
Use a smooth idling cam, the car will be more fun on the street and usually faster..
#43
I put in a Riv Nut in the frame and now I'm looking for a spot on the motor to tie to. There is one open spot on the head behind the power steering pump. Its pretty tights so I'm not sure it will work. I was also looking at the head bolt or exhaust bolt as an option. I also noticed I have an open motor mount bolt hole, but you mention "2-Bolt Blocks are not too strong in the pan rail area/mount area" Not sure I'm interpreting your meaning correctly or not. This is a 455 block with the 5 mounting holes. Its in a 68 bird so I'm only using two mounting points. This open mounting hole looks like a perfect spot. |
#44
Go for it.
Tom V.
#45
Are there any pics of the plastic coated wire strap arrangement please. I would be interested to see how this has been done for my 600HP street/ strip firebird.
#46
Old thread I know, but I've run the chain from the cylinder head to the frame rail on a couple cars. My 87 GN currently has one, and it definitely does its job.
#47
I thought I might need some type of torque strap for my motor, but I used these Butler mounts and I have virtually no movement of my motor regardless of condition (idle, WOT, hard shifts). They are almost like a solid mount. Still no transmitted vibration either. I'm pretty happy with them. Not a good option if your motor is already in your car, but if you have your motor out, it's something to consider.
https://butlerperformance.com/i-3164...tegory:1393551
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
