Old 09-15-2019, 11:38 PM
ponyakr's Avatar
ponyakr ponyakr is offline
"...There is a better Carter elec. solution with the P4602RV pump..."
https://www.ebay.com/p/Electric-Fuel...02RV/191631775
Old 09-16-2019, 03:36 PM
Formulajones's Avatar
Originally Posted by 78w72 View Post
can you post a pic of the regulator mounted on the engine?
Here ya go.
Old 09-16-2019, 04:32 PM
78w72 78w72 is offline
thanks. looks good. i was wondering how far from the block it was. right now i have mine installed up top closer to the carb, its just free floating in the braided -8 line which is strong enough to keep it suspended. yours is great for a stealth look, i wasn't too concerned with that on this car but will keep it in mind.
Old 09-16-2019, 04:49 PM
I don't think the picture shows it well but the regulator is actually a good distance away from everything all around. You can easily stick your hand on all sides. So it gets a good amount of air flow all around it. I do all the cars this way and it's never posed any issue. It's out of the way and not visible from the top, yet it's easy to set fuel pressure from the bottom.
Old 09-16-2019, 05:44 PM
scott70's Avatar
scott70 scott70 is offline
There's a recent interesting mechanical pump dynoing on engine master challenge on motor trend on demand.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 09-17-2019, 10:09 AM
rohrt rohrt is offline
I wish they made a fuel regulator that looks like a regular stock fuel pump. Then I could run an in tank pump and keep a stock look under the hood.
Thread Tools
Display Modes
