Old 09-15-2019, 07:10 PM
427454 427454 is offline
Default 1970 gto convertible 455 HO
checking to see how rare this car would be its automatic, lots of options like ram air on option sheet, air conditioning , power brakes and steering,am/fm 8 track,color is atol blue, white top and blue interior. checking numbers on engine code yh on front of engine 9799140casting on rear cant see date on rear. any help is appreciated. Thanks
Old 09-15-2019, 07:54 PM
That is not correct engine code for 70 GTO 455 Automatic.
Would be YA for early build - YC for later build.
#64 Heads would be correct for that engine.
It's a 1970 Fullsize Body 455 (YH) engine that would have come with #15 Heads.
Rare car though.
Only 241 455HO with RamAir Induction GTO's built with Automatic.
302 Manual
No breakdown between Hardtop and Convertible
A top choice color combo on top of that.
Old 09-16-2019, 11:56 AM
Post some pics of the car and the PHS Invoice if you can.
Maybe even in the 70-72 GTO/Lemans/Tempest category sub-section.
It will draw more comments/interest in that section.
Think we have documented about 5 or 6 455HO/RA Auto Convertibles ... so far
Only 2 documented 455HO/RA 4speed Convertibles ... so far
Old 09-17-2019, 10:57 AM
In case the seller wants to dance around about the YH or claims it as original -
here is where the partial VIN should be stamped.
Circled in Red.
Name:	PMD block code vin 4.jpg
Old 09-17-2019, 11:23 AM
steve25 steve25 is offline
With a 455 from the factory it should have a 12 bolt rear, not a 10 bolt so confirm that .
Old 09-17-2019, 09:05 PM
It has 12 bolt and still has spiral shocks still on, its a low mile car 46,000 and change. 455 is not matching
