Turn signal switch
Does anybody know where I can obtain a turn signal switch for a 64 GTO with out tilt column?
You might try Danchuck,I`m willing to bet a 67 chevelle would work on a 67 Pontiac. From looking at their site there is 2 different signal switches for the 67 model year (chev). One is a Delco and the other is a Cloyles. You have to determine which one you have ? Ask some person you know who owns a 67 Chevelle or Buick or Olds if they have replaced their signal switch? And I`ll also bet a tilt colum switch would work to .
THere are 2 switches listed for 64 model year. I have 67 on the brain. I still stand by what i say above though, there can`tbe that much difference between Chev and Pontiac signal switches. You would have to check the circuitry for sure on the Chev versuse Pontiac switch.
Thanks for the info, mine has the u shaped connector and the chevelle has the straight one. I am ebaying right now for the right one, have a line on the one I need hope the bidding goes in my favor. It's now at 67.00, lets keep our fingers crossed because that about what its worth. I need brake lights!!!
