Old 08-16-2002, 11:34 AM
Amtcoastie76's Avatar
Amtcoastie76 Amtcoastie76 is offline
On my 65 Cat I noticed that my brake pedal when applied does not come all the back up to its full position thus keeping the brake light on. Is there any way I can adjust the pedal or the rod going into the master cylinder to allow the pedal to spring back to its original height to correct this?
Old 08-16-2002, 11:59 AM
Txbobcat Txbobcat is offline
There is no adjustment of any kind on the pedal or rod. However the brake light switch is adjustable so just move it with the 2 nuts provided to get the brake lights off. If you need any brake parts which I doubt contact me. I converted my 65 to disc and everything I took off was good. ie drums power booster etc.
