Old 02-01-2024, 03:16 AM
Default 1962-1964 AT shift linkage
I need the shift linkage for a full size 1962-1964 Pontiac with automatic transmission floor shifter and console. The pieces I need are UNDER the floor. One is a bell crank and bracket that the short rod from the shifter goes to. The other is an adjustment rod that go from the bell crank to the shift arm on the transmission. I believe the 1964-1965 LeMans/GTO used the same system. Thanks.
