Switching to power discs and Im wondering what the button is for on the prop valve. If I gotta do something with it during bleeding what do I do?
Thanks!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
Thanks!
I believe its for the "brake" light reset. If one half looses pressure it turns on. So after bleeding need to push it.
the button should reset itself during bleeding. occasionally they do stick and need to be reset manually. mike
Thanks for the replys guys, sounds like a good answer. Ill buy it.
