Old 08-22-2010, 07:32 PM
grandville455's Avatar
grandville455 grandville455 is offline
Thumbs up !!! NEW BEST IN THE HEAT!!!
We'll The weather was very simliar as it was two races ago with todays being worse!..On a fairly fresh track maybe 50-75 cars down it, the car goes 11.87@113.20!!! with a 1.70 60 foot! , and a 7.55 1/8th mile @ 91.03 mph.Sorry for the swearing my bro was happy,lol . Two races ago was 12.15@111.51. After that the track went to crap and i started unloading the tires after 4-5 feet out everytime except one more where it went11.91@133.33 at 1 pm!.. then at 3.30 in the HEAT it goes 12.05 spinning with a 1.78 60 foot still, that DA WAS over 3800 FEET!!.If it would have hooked and went 1.70 like in the morning would have been a 11.89 at that ALTITUDE! THAT CORRECTS to 11.33@118!! So the convertor absolutley ROCKS!.. I tried stiffing the back didn't work, tried softening didn't work, then i tried 16 psi in tires still didn't work usually run 19 psi. Now was it the bad track or is my front coming up to quick and unloading the rear again? cause everytime its 4-5 feet then it spins them! it hits hard and grabs ,but right after it lights them up, that was from two guys watching the tires for me.
http://smg.photobucket.com/albums/v2...0822104307.mp4
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 08-22-2010, 07:48 PM
mchell's Avatar
mchell mchell is offline
time for a 28"- 30" tire dude.......nice improvement
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 08-22-2010, 07:58 PM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Thumbs up Definitely Going in the Right Direction!! SWEET!!
That is a nice improvement! Good weather, good track and finding exactly what it wants for launch rpm will be GREAT!!!!!!!!!!
PHILLYGOAT
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
Old 08-22-2010, 08:08 PM
Nice! Keep the rear about 50/50 and slow the front end down a bit or try limiting front travel or possibly both.
Old 08-22-2010, 08:21 PM
hal101's Avatar
hal101 hal101 is offline
11.87@113.20!!! WOW that rocks
Old 08-22-2010, 08:35 PM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
Yeah, what he said.... you dont have enough forward footprint on the ground... width not as important as height when you makin the torque you are while tryin to move such a heavy car.... im doin 1.59 60's with a 9x28.5 Pheonix tire... 50/50 rear shocks, 80/20 fronts...solid rear bushings and boxed control arms in the '62...also...upper mounting points have been moved up bout 3'' or so...
Good to hear she makin some power!!!
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!!
Old 08-22-2010, 08:44 PM
Thanks Guys! I just watched it in slow motion.. it isn't the tires it is the front end come up too quick and topping out , then it comes back down and that is when it is unloading the tires... I was not the only one spinning my bro went from 1.60 to 1,67, He runs a brake with a 5200 stall and 26" slicks too and other cars were spinning too.. I think I will go to my 60/40 setting from the 80/20 i am at now and leave the back at 8 clicks.. Samething happened when i went to this new setup two years ago when it was 90/10 too much lift too quick slowed it down and it rocked, and get a good track next sunday cause it will be a bracket day with much better prep and cooler!..
Darby
Old 08-22-2010, 08:57 PM
tc's Avatar
tc tc is offline
Great time! Get a chance to check the flash? My car lifts and back down quickly and will spin a few feet out if I have too much air in the 28" dot tires. I unhooked one side of the swaybar to try to make the lift last longer, not sure if that did anything. Once again, super job. Also, last year I had 30" slicks and no problem hooking up.
Old 08-22-2010, 09:01 PM
,Tom
On the runs that it hooked i didn't lol...but the ones that it unloaded it was around 4400 so i am guessing it was very close to 4-4200, on that 87 run it went thru at 53-5400 is all!! cliff was right it flashes quickly! i brought it up to 28-3000 on the foot brake then flashed from there.very tight on top!
Darby
Old 08-22-2010, 09:04 PM
you might need to dial in a couple more degrees of pinion angle in your car...it will help to keep rear tires planted... and your front end up
chuckies76ta's Avatar
Great run Darby..
Charles
Old 08-22-2010, 09:30 PM
Ron H's Avatar
Ron H Ron H is offline
Congrats. On your way to needing a roll bar!!
Can you tighten the front shocks?
Not sure if you want to go to a taller tire just yet. That could cause the coverter to slip more on the top end and you could lose mph.
Pinion angle may help as suggested as well.
68 Firebird
Are you running with the wind or breaking it?
Old 08-22-2010, 09:58 PM
Ron'
Yes I can and i will be going to the 60/40 setting, but i am telling u guys the track sucked today also. The thing with this car its not of the norm ,lol so not alot of stuff available to change stuff like that. Will not be changing tires at this time, plus i would loose all my gear multiplication cause i can't go any deeper in gear,none made unless i go to whole mod r/e. and not doing that either too much money!
Darby
Old 08-22-2010, 10:09 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Congrats Darby.
Sounds like you might wanna look into some AFCO BNC double adjustables up front,those shocks are made especially for big heavy cars like yours.
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 08-22-2010, 11:17 PM
A.W.Dille A.W.Dille is offline
Darby I love the way it runs. Great job. By chance have you tried an air bag in the RR spring only? I'm not sure if it would work as well in your car as it does in an A-body but may help keep the RR tire loaded more and may help traction farther out.
Old 08-22-2010, 11:25 PM
Badbird69's Avatar
Badbird69 Badbird69 is offline
Congrats Darby,
I agree, slow the front shocks down.
Did you day Al might prep the track better next weekend? What's the occasion?
Dick
Old 08-23-2010, 06:13 AM
Alan, I have air bags in both and set at 6 on drivers side and 15 on pass.. anymore and it gets to bouncy not letting the shocks do their thing.
Dick
Its just a regular bracket day and track prep is much better!, plus they had a track rental up here on saturday and I am sure there was alot of street cars there I heard like 80 cars.. I just know from racing here it will be night and day difference, Yep I agree on shocks u can plainly see it in slow mo the car comes up and comes up fast then it tops out and comes back down and that is when it spins.
Darby
Old 08-23-2010, 09:29 AM
JoePapa's Avatar
JoePapa JoePapa is offline
Very impressive times, especially for a vehicle that is more than 2 tons in weight! 11.87 with 4600lbs? Awesome man!
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
Old 08-23-2010, 09:43 AM
Torment's Avatar
Torment Torment is offline
I had my hands full keeping it straight with mine for the first 200ft on Saturday too Darby - similar weather I think. It was hooking at the line but slipping around a bit thereafter. At BIR I can drive it with 1 finger on the wheel... Gotta love The Rock!
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 08-23-2010, 09:57 AM
Chris
So u were there with the track rental guys? or u were one of them? Did they do anything to the track sat? cause it sucked sunday!
Darby
