Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-10-2014, 10:31 PM
cmpgto's Avatar
cmpgto cmpgto is offline
Are these still available? I'd like to get a set as well.
  #82
Old 01-14-2014, 04:55 PM
shotgun shotgun is offline
PY Staff -Tech
Yes, have a few sets left.
They are $40.00 shipped per set.
If using paypal use: mike@mrgto.com
If using another form of payment send me a P.M.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
  #83
Old 01-18-2014, 09:34 PM
elefantrider's Avatar
elefantrider elefantrider is offline
What is the correct washer sequence on the bolts? Mine had bolts in from the frame, no washer, then an split ring washer before the nut on the top side.
  #84
Old 01-30-2014, 07:04 AM
kencar62's Avatar
kencar62 kencar62 is offline
They are $38.00 shipped per set.
PM Sent
  #85
Old 03-28-2014, 03:54 PM
PY Staff -Tech
Just wanted everyone to know, the price went up $2.00.
They are $40.00 shipped with PA residents adding 6% tax.
  #86
Old 03-29-2014, 03:00 AM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
Just installed mine today and the fit perfectly!!
Thank you.
  #87
Old 03-29-2014, 10:09 PM
goatwgn goatwgn is offline
I installed mine back in January and they fit great, worked great.
  #88
Old 05-03-2014, 07:58 AM
PY Staff -Tech
Supply is getting low!
  #89
Old 05-04-2014, 12:21 PM
carsmymistress carsmymistress is offline
Just sent payment via paypal for a set. Thanks for making these available.
1969 Pontiac Firebird 400 Convertible
Don't drink and drive. I really don't want you as a customer
  #90
Old 05-16-2014, 08:33 AM
PY Staff -Tech
Bump
  #91
Old 06-06-2014, 10:44 PM
Installed mine. Motor mounts don't settle down onto the plates enough to get the bolts straight in. Have tried numerous times jacking up and setting down the motor again. Still don't align. Might try jacking up rear of trans. Anyone have a similar experience and solved it?
  #92
Old 06-07-2014, 12:09 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
I had a similar issue getting mine to drop onto the frame mounts. I cant remember exactly what I did. I think I had one bolt in and then started to jack up the car under the engine crossmember with the intention of unbolting the motor mount from the engine and try it a different way when the frame must have flexed a bit and it dropped on. Hope this helps and works for you.
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
  #93
Old 06-07-2014, 07:29 AM
chrisp chrisp is offline
What was the reason you needed them for ?
  #94
Old 06-07-2014, 09:38 AM
Reason I got the plates is the pan was touching the crossmember and the tie rods seek fittings indenting the pan. Will try jacking up on crossmember again. Ugh
  #95
Old 06-08-2014, 01:07 AM
are any thinner versions of these plates available yet?
  #96
Old 06-08-2014, 08:28 AM
Different tie rod ends with proper fitting location are available , aftermarket pans are a problem as is the engine mounts that are from India try using just 1 spacer . Also too thick trans. mount is no good / bent or raised cross-member as well .
  #97
Old 06-09-2014, 10:22 AM
IMHO, the plates are too thick for my car, putting the motor mounts in a bind on my '65 GTO with manual trans. Thinner plates would be better. Let me know if/when you will be doing those.
As a temporary solution, I have the driver side installed only. This is not ideal because it is very obvious that the engine is leaning.
Also one needs to be careful of hose to a/c belt clearance. On a tri-power a/c car, the passenger side plate will cause the a/c belt to saw into the upper hose...... makes for a big mess when she goes!
  #98
Old 01-16-2015, 09:32 PM
GTO4EVER GTO4EVER is offline
Default 69 Judge
Finally got the car in running condition, now just need to finish the interior. The 1/4" spacers worked perfectly! Everything lines up as it should. This forum was a tremendous help in learning about the problem and providing a remedy. So grateful to Mike for helping!
  #99
Old 08-24-2015, 05:38 PM
coonhunter70 coonhunter70 is offline
Are these spacers still available?
  #100
Old 10-19-2015, 11:23 PM
imposter's Avatar
imposter imposter is offline
i am wondering the same as well do these go between the motor and the mount or between the frame and chassis mount
