Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 04-13-2014, 07:28 PM
cgeise's Avatar
cgeise cgeise is offline
Default Spring Cleaning
Time to clean stuff out -- FOR SALE
Water cross-overs -$50 each (2)
Manley Valve springs 221425 used but good $100, one set with ti retainer's $200
Comp cams 948 Springs $75
Edelbrock stud girdle $75
Billet roller cams
(1) turbo grind - $250
(1) new ultra Dyne 280/283 -- $275
(1) used, nice 284/290 -- $200
(1) used 50 mm 282/292 --$250
Moldex billet crank - std, std - $1750
Accusump with electronic control valve and 25lb switch $200
One set EFI fuel rails -- edelbrock - $50
Tiger intake -- Flange cut .750 down with turtle $250
Tci Damper - the "Rattler" $ 150
Crower roller lifters - 14 extreme duty tall, offset lifters with pin oiler--$150
One set Ross pistons for Tiger heads for 4.350 bore with pins --$250
One set Diamond Pistons for tiger heads, side coated for 4.375 bore with pins -- $350
One set Smith bro push rods 3/8 buy 165 wall (8) 9.00 long and (8) 9.050 long $75
Old 04-13-2014, 07:40 PM
mgarblik mgarblik is offline
Please tell me more about the Moldex crankshaft. 3.25 or 3" ? Standard Pontiac or BBC rods std. Balanced? and if it is any idea of the bob weight? I assume it has been run. Any run history? Does it have a standard Pontiac long keyway or 2 short ones? With or without 1/4 keyways for a blower hub? I guess yiou can tell I am interested. Most important to me, what is the stroke? Thanks for the info.
Old 04-13-2014, 09:21 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
curt can I get the specs on the turbo cam?
Old 04-13-2014, 09:26 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
pic of accusump please
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 04-13-2014, 09:35 PM
aaronman aaronman is offline
Curt - PM me the details of the 50mm cam. I could use a back up if the lobe lift, LSA and duration at .050 are close to my current stuff. Thanks.
Old 04-14-2014, 12:06 AM
pontsd pontsd is offline
Pm sent
Old 04-14-2014, 12:32 AM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Curt,
What are the main and rod diameters on the crank you have for sale?
Thanks,
Aaron
Old 04-14-2014, 04:22 PM
cgeise's Avatar
Crank is a 4.5 in stroke 3 in main with bbc rods-- repaired after one rod scuffed it was magged and re-heat treated after repair back to std size - it would have been fine at 10 or 20 under, but I didn't want that. Standard single keyway and when last used it was balanced with Oliver steel rods.
Old 04-14-2014, 05:32 PM
I'm locked into a 4.25 stroke, damn.
Old 04-14-2014, 08:39 PM
Curt - I'll take the 50mm cam. Check your pm. Thanks!
Old 04-14-2014, 09:30 PM
cgeise's Avatar
Sorry for the screw up -- but the cam listed as 50mm is really a 55mm -
Old 04-14-2014, 10:48 PM
69camarox 69camarox is offline
is the tiger intake ported if so what size is it at the intake gasket
Old 04-14-2014, 10:50 PM
JD's Avatar
JD JD is offline
Interested in the crank, intake and pistons if they are still available. Sent you a PM with some questions.
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 04-15-2014, 12:48 AM
Donovan Donovan is offline
Hey Curt...
Which FI rails are you selling? victor or super victor?
Old 04-15-2014, 09:02 AM
RA462's Avatar
RA462 RA462 is offline
What is the lobe lift is on that 55mm cam? LSA?
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 04-15-2014, 11:16 AM
cgeise's Avatar
Originally Posted by Donovan View Post
Hey Curt...
Rails were on the " big" Victor - race Manifold
Old 04-15-2014, 11:17 AM
cgeise's Avatar
Ill get it later today for you.
Old 04-15-2014, 11:42 AM
66sprint 66sprint is offline
Curt
If the EFI rails are not already spoken for, and if they are Edelbrock #3634 and new, I will take them.
I will send PM too.
Chris
Old 04-15-2014, 12:10 PM
I'm interested. May I have a few pics?
Old 04-15-2014, 12:52 PM
cgeise's Avatar
There like new fuel rails - -Pics really ?? Not trying to be a jerk here but --
