Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
525 Race Engine
525 Pontiac engine will all the good stuff
Built by Neal Owens for John Bailey's RAM Drag Radial car:8.80 @ 156 @ 3600# through 3" exhaust first clean pass seasoned IA1 block, never hurt, fully machined by LSM all the bells and whistles, roller cam bearings, keyway lifter bushings Bryant crank MGP rods High compression pistons with trick ring package Jesel lifters, Smith pushrods, Jesel rockers Edelbrock Performer RPM heads...probably the best on the planet..no expense spared..years of development work ..all work completed by Tommy Slawko who does NHRA Pro Stock stuff with matching Victor intake with lots of work:Copper/Beryllium valve seats, Titanium valves, PAC springs Stefs pan w Moroso external oil pump BOP belt drive CSI water pump Fabricated valve covers made close to 1000HP on a chassis dyno Has less than 40 passes, intake, valve covers and pan removed for inspection $15000 I will take partial trades for engines or engine parts, Ram Air IV V, 455 HO, SD, BBC, ???
1989 Automotive Hall of Fame Inductee |
if you still have 525 motor call vance at 7402250390 thanks
message sent
77 Trans Am All Steel, on 10" tires 8.30 @ 165 mph 3,380 LBS Mat it! Spray it! Chute it! Just another 8 Second Pass! |
I have pulled both heads and one piston/rod to take pics. Coated rod bearings look like new. I was asked about gasket issues between the center cylinders and there are no issues there.
This is a steal just for a pile of parts, I understand the reservations about buying "a used up race engine". I would take this to either Bill Trovato, BES, SAM or other reputable engine builder to evaluate, assemble and dyno and you would still be half the price of building an engine like this from scratch. There are no substandard or discount parts used anywhere. $2400 Jesel lifters, $2000 Jesel Pro Series rockers, $3000 Bryant crank, $1800 titanium valves, $1500 BOP belt drive with all the accessories crank trigger water pump etc, Stefs pan, Moroso external oil pump, Moroso vacuum pump ATI balancer with drive mandrel, fabricated valve covers, coated titanium wrist pins, coated pistons and bearings, IA block with bronze lifter bushings, all parts except the block in this engine have less than 40 passes and everything looks like new. The block is good and has been used and never hurt.
Wow, that is an awesome deal for someone!!
Dave Polichena |
Is there a possibility of bringing this engine to Norwalk ?
I would if I had a confirmed sale and reimbursed for expenses
PM sent
bump deal fell through
bump
I will separate top end, sell short block separately
1989 Automotive Hall of Fame Inductee Last edited by KO; 09-12-2016 at 01:25 PM. |
$10K long block, no carb, ignition timing belt or oil pan/pump
correction, made a mistake has 55MM slider cam bearings
bump $10K long block:
IA1 block perfect condition all machine work done by LSM, 55MM cam bearings, bushed .937 keyway lifter bores, main bearing spacers for 340 mains, block has never been damaged or blown up ever, one the the original IA blocks ran for years as a 477 then ungraded to correct 525 CID: 4.365 bore material left for future clean ups billet pistons with ultra diamond finish rings, coated skirts, gas ported, diamond coated ring lands Bryant billet crank w center counter weights 4.37 stroke, 340 mains, 1.88 rods MGP rods Edelbrock RPM heads by SLAWCO, copper beryllium seats, titanium intake and exhaust valves, Ti retainers, PAC springs #350 seat 1000# open @1.00" lift Jesel lifters Jesel Mohawk rokers 1.80 ratio Manton pushrods w cup type tips Extensively modified Victor intake Complete short block with heads lifters rockers pushrods, will need oil pan timing components and balancer to complete, less than 40 since built, everything inside is like new $10K is less than what just the parts would cost ($7500 for just the rotating assembly alone)
more pics
bottom end, bearings look like new
You willing to sell the crank?
selling either shortblock or longblock only kinda useless without a crank
another $2500 and you can have the complete short block
top end pics
