Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-30-2020, 06:02 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
The Pontiac heads were always alot more $ than the Olds or Chevy heads. I've been waiting for them to come down as I knew the eventually would. I ended up buying 2 sets.
Old 11-30-2020, 06:11 PM
PontiacJim1959 PontiacJim1959 is offline
I just bought a pair of bare heads for that price myself. I can build them later to fit whatever engine I put together in the future.
$957.00 for the bare set and free shipping.
Old 11-30-2020, 07:39 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
I ordered a set.
Old 11-30-2020, 10:28 PM
PONTYRAT1 PONTYRAT1 is offline
Can these be wide ported I know pushrod holes need to be plugged up
Just havent seen any info in them except for early on
Old 11-30-2020, 10:59 PM
ta-69's Avatar
ta-69 ta-69 is offline
I ordered a set today 1140 shipped. No tax, the only benefit to living in New Hampshire.
The Following User Says Thank You to ta-69 For This Useful Post:
Old 12-01-2020, 04:44 AM
Dragncar Dragncar is offline
I do not see a option to get them without pushrod holes drilled so you can wide port them without welding up and re drilling. They weigh less than E heads, that materiel has to come from somewhere. Are the decks as thick, can they be ported as far as a new E head ?
And they are made overseas, there is that to consider for some.
But they are a bargain.
Old 12-01-2020, 12:34 PM
gillyiowa gillyiowa is offline
Default heads
i snagged a bare set for $485
Old 12-01-2020, 01:01 PM
How did you pull that off? A single head was $478.50 during the sale.
Clay
Old 12-01-2020, 07:08 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Clay
Probably only bought 1.
Old 12-01-2020, 07:48 PM
blueghoast's Avatar
The decks are the same and there is a lot more room to port better then the eddy's for what I could tell. I did a set of eddy heads a while back 10-years.
I spent over a week on them, I just did a set of SM heads and and matched
the one's I did 10-years ago where I got 305 cfm. I actually got all most 315
In just 2-day's. Every thing seams better, the matirial the valves the valve job
I was able to remove the pushrod bulge almost completely. So I think they
are a lot better.
GT.
Old 12-01-2020, 08:21 PM
68azbird 68azbird is offline
they have fried rice in the water passages. you must put the heads in boiling water then add some soy sauce and dump out in a bowl and eat.
It is easier to fool a man than it is to convince he has been fooled
Old 12-02-2020, 01:36 PM
74Grandville 74Grandville is offline
Originally Posted by mysticmissle View Post
no it says pair down below in the description. I was able to order a set this morning. I forgot to get the guide plates so if you try to order again, make sure you include them.
what's the part number for the guide plates.
i'm guessing this would work. Edelbrock 9667
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 12-02-2020, 01:48 PM
Pce251.1026
Old 12-03-2020, 03:06 AM
Brian Baker's Avatar
Great info, keep it coming. I figured they were probably around 280-cfm as cast (like the E-heads).
Old 12-04-2020, 10:36 AM
i put my 1.83 shaping valve in the bowl and it just floats around. definitly a much larger port then a normal D-port. they remind me of a RAV bowl I saw once.
looks like they use 45 degree seats on the intake. the bottom cut looks radius.
additional things i had to buy, spark plugs, head bolts, pipe plug and nipple for heater core.
Old 12-04-2020, 11:05 AM
mysticmissle's Avatar
you got them already? or was this a previous order?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 12-04-2020, 11:24 AM
i was probably the first to buy.... i ordered mine at 10pm thursday night once the price changed. The site said "in-stock" it now says "build to order"
I got mine Wednesday. with what happen last year, i have a feeling they ship them out as they are available. Some folks had to wait 6+ months.
The Following User Says Thank You to 74Grandville For This Useful Post:
  #38
Old 12-04-2020, 12:16 PM
Did you get the complete or bare heads? What do you think of the quality so far?
  #39
Old 12-04-2020, 12:26 PM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
There was/is a sale on speedmaster Olds heads, $228 each, bare.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
  #40
Old 12-04-2020, 03:52 PM
I am no expert, but they look really nice. I got the complete heads for FT. I will end up taking them apart to go through them. There are some sharp edges on the intake ports that I want to clean up as well as elongate pushrod holes for 1.65 rockers. I read they are setup for .580 max lift. The valves are 1.8 installed height.
I also want to ensure the guides are not too tight. There is no slop in the valve which is good, but I’ve had a valve seize before and don’t want that to happen again.
I’ve only played with d-ports so having such a nice head is new to me.
