Tri-Power Tech 57-66 Tri-Power Talk
Old 06-23-2023, 10:40 AM
Dick Boneske's Avatar
Default '66 Tri-Power with Vacuum Linkage, Automatic
I'm building a '66 Tri-Power for an automatic GTO. I have all the components, but do not know which bracket is used on the center carb throttle lever--the bracket that actuates the kickdown switch.. As you know, there were many different styles used through the years. I believe the '66's used the same bracket as '64 & '65, but I want this to be correct.
If anyone has a photo of a correct '66 setup, I'd appreciate your sharing. Here ar the carbs after assembly, before mounting the vacuum switch, kickdown switch, vacuum diaphram, etc. I will post pictures after this is all in place.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-23-2023, 03:45 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
This question has been answered before for the 3x2’s with automatic.
1964-1965 the automatic kick down switch was under the hood mounted to a bracket off the LH side of center throttle plate.
1966 was inside under the dash just above the accelerator pedal.
ID:	614741   Click image for larger version
ID:	614742   Click image for larger version
ID:	614743   Click image for larger version
ID:	614744   Click image for larger version
Old 06-23-2023, 11:27 PM
You are correct about moving the kickdown switch under the dash, but you were off by one year. That Change was made in 1967, to both the big Pontiacs & Tempests & GTO’s. I have had a few ‘66 automatic Tri-Powers in my shop. They all had the switch mounted on a bracket held down by the center carb hold down nuts.
BONESTOCK GOATS
Old 06-24-2023, 12:19 PM
694.1 694.1 is offline
That would look awesome on an OHC!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 06-24-2023, 05:07 PM
Kenth's Avatar
Kenth Kenth is online now
1966 GTO Tri-Power A/T has the downshift control switch #9783241 (#1242101) inside under the dash just above the accelerator pedal.
1965-66 Pontiac Tri-Power A/T has the downshift control switch #9781141 (#9785545) on a bracket mounted to the center carb.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-25-2023, 12:54 AM
60sstuff's Avatar
Really, I don’t even know why I bother trying to help you with your questions pertaining to a 1966 GTO Tri-power with automatic.
Waste of my time!
