OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-24-2022, 08:37 PM
Jeff Hamlin's Avatar
Red face Finally Buttoned up the short block
Weekend weather was outstanding, near 90 today gave me enough motivation to pull this back out and button up the bottom end.
All the bolt-on's have been done, so now I'm down to the Head and Cam assembly.
But will still likely be running in a slow gear. I need to get the Carb project wrapped up then I'll get back on this engine.
Name:	SPRINT 28 (1).jpg
ID:	589337   Click image for larger version
Name:	SPRINT 28 (2).jpg
ID:	589338   Click image for larger version
Name:	SPRINT 28 (3).jpg
ID:	589339   Click image for larger version
Name:	SPRINT 28 (4).jpg
ID:	589340   Click image for larger version
Name:	SPRINT 30 (1).jpg
  #62
Old 04-24-2022, 08:39 PM
Thumbs up Pick-Up Clearance
Wanted to be sure I was as close to the bottom as I could get.
Name:	SPRINT 29 (1).jpg
ID:	589342   Click image for larger version
Name:	SPRINT 29 (2).jpg
ID:	589343   Click image for larger version
Name:	SPRINT 29 (3).jpg
ID:	589344   Click image for larger version
Name:	SPRINT 29 (5).jpg
ID:	589345   Click image for larger version
Name:	SPRINT 30 (4).jpg
  #63
Old 04-24-2022, 08:44 PM
See you soon, I hope.
  #64
Old 05-27-2022, 06:46 AM
Talking Small advances
Taking head over to shop this weekend.
Otherwise just tackling small task when time allows.
OE hardware getting inspected and cleaned up.
Had the carb gone through and started putting the manifolds together just for the hell of it.
Name:	OE HARDWARE.jpg
ID:	591607   Click image for larger version
Name:	MANIFOLD DETAIL 1.jpg
ID:	591608   Click image for larger version
Name:	MANIFOLD DETAIL 3A.jpg
ID:	591609   Click image for larger version
Name:	MANIFOLD DETAIL 7F.jpg
ID:	591610   Click image for larger version
Name:	MANIFOLD DETAIL 7H.jpg
  #65
Old 05-31-2022, 05:36 AM
Shop was closed for a long holiday weekend
Will try again this weekend.
Went ahead and started setting up some of the bolt-on bits and free up some space in the bins.
So dam close...
Name:	SPRINT 31 (1).jpg
ID:	591851   Click image for larger version
Name:	SPRINT 31 (3).jpg
ID:	591852   Click image for larger version
Name:	SPRINT 31 (7).jpg
ID:	591853   Click image for larger version
Name:	SPRINT 32 (1).jpg
ID:	591854   Click image for larger version
Name:	SPRINT 33 (1).jpg
  #66
Old 06-01-2022, 01:15 PM
Jeff, looking at your engine I'm noticing what is and isn't painted blue. What do you think was the factory correct situation? For example the water pump? The bolts holding the accessory block etc? In other words how complete was the engine when they painted it and what parts were painted before assembly.
I know we've talked before about this but the one I keep seeing on 68-69 is virgin engines only show black paint on the oil fill tubes. Also would the exhaust manifold have been painted? If not that means the intake would have either been painted blue ahead of assembly or not painted blue?
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
  #67
Old 06-01-2022, 07:21 PM
Thumbs up DETAILS.
I've always taken a few creative liberty's with my past builds. Such as unpainted Hardware, Manifolds, Water Pumps, etc.
All to add a little pop/wow to the under hood experience
However this build will be a facsimile of the early PMD photos I have on file.
Once I get it all together Everything will be shot again with the Metallic Blue.
Then all the little non-blue bits will be installed as well as the one year only paint detail of the fins and letters.
If you looks close at the B&W photos you can see the items painted Vs the things not, as well you can see overspray on some of the hoses. But I don't think I'll go that far
Name:	66 SAE PIC  (12).jpg
ID:	591967   Click image for larger version
Name:	66 SAE PIC  (8).jpg
ID:	591968   Click image for larger version
Name:	66 SAE PIC  (9).jpg
ID:	591969   Click image for larger version
Name:	66 SAE PIC  (10).jpg
ID:	591970   Click image for larger version
Name:	66 SAE PIC  (11).jpg
  #68
Old 06-01-2022, 10:23 PM
Nice work! I just got my head back on today as well as the other accessories. This weekend I’ll get the cam housing and manifolds on. Hoping to drop her back in the car next week.
1969 Bonnie Cvt
  #69
Old 06-23-2022, 05:56 AM
Unhappy VALVES & VALVE SPRINGS
Dropped Head off last week and for the first time in many years this head could use both Valves & Springs.
I'm checking the normal known sources, Kanter, EGGE, Woodland and Rock but would love to hear from anyone who may have gone a different path to secure these.
Cheers.
  #70
Old 06-23-2022, 08:13 AM
My 69 base engine is back together and dropped it in the car last night. I ended up finding NOS valves on eBay. However they are not the same as Sprint valves, same diameter but the stem is shorter. They were quite inexpensive, $85 for the intake valves and $30 for the exhaust.
Most of my valves were good but a few had some wear on the stem. Could have ground them but for the low cost of the NOS valves I figured why not.
1969 Bonnie Cvt
  #71
Old 06-23-2022, 12:17 PM
jrunner jrunner is offline
Cheers.
Maybe ferrea ss valves has something in stock?
  #72
Old 06-24-2022, 06:23 AM
Thumbs up
Thanks.
I'll pass that on to my machinist. He also has a few obscure sources he is checking with.
Waiting to hear back from EEGE.
Their online cat has incorrect information and I want to be sure before pulling the trigger.
Last resort is following Rich Mc's procedure of using custom lash caps,
but that will be a very last resort.
  #73
Old 06-24-2022, 08:20 AM
66sprint 66sprint is offline
North
With the shorter valve stems, how did you make up for the extended valve tip the OHC has?
  #74
Old 06-24-2022, 05:21 PM
Arrow
For reference;
  #75
Old 06-30-2022, 06:57 AM
Exclamation EGGE & KANTER ARE F'ING USELESS
Stepped in sh!t and was able to secure NOS & NORS parts.
All's right in the world again
Name:	66 4BC VALVES.jpg
  #76
Old 08-22-2022, 10:46 PM
PepinoBBB PepinoBBB is offline
Hi Jeff , I read in another post that you part out a few H body station wagons. And just wonder if by any chance do you may have a complete automatic shifter for an H body Pontiac Sunbird for sale. Thanks in advance. 323 6036943
  #77
Old 08-23-2022, 06:41 AM
You must have me confused with one of the other Jeffs
I only deal with Pontiac OHC stuff and this post is about my build.
Cheers.
  #78
Old 08-23-2022, 05:48 PM
He must have been thinking of me Jeff, I may have a complete shifter, I will have to check. I will PM him either way
  #79
Old 08-29-2022, 07:21 PM
Default Well that was quick...
Holy Hell this has been mind-numbing, but I'm still in it.
ID:	597467   Click image for larger version
ID:	597468   Click image for larger version
ID:	597469   Click image for larger version
  #80
Old 08-30-2022, 08:54 AM
Doctor john Doctor john is offline
Great work! What are the part numbers for the accessory housing bearings and seals? How did you find them?
