Old 09-06-2011, 06:09 AM
Cammer-6 Cammer-6 is online now
Originally Posted by sehorn View Post
No idea. After doing tons of research I have found a fair amount of conflicting information.
The steel wheels and hubcaps are 14" ( will post pics later, pretty ugly), not 15 as I stated earlier. The sway bar is not 1", seems to be about 3/4".
only TAs got the 1 inch bar
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #82
Old 09-06-2011, 09:51 PM
sehorn sehorn is offline
These hubcaps the original per the PHS?
  #83
Old 09-06-2011, 10:46 PM
yeh looks just like what i had in mind.
If someone has the GTO resto guide, it should have pictures of all 69 caps.
Mine is buried in a box, under some other boxes.
  #84
Old 09-07-2011, 05:25 PM
FunctionalShaker FunctionalShaker is offline
Those are the deluxe hubcaps called for on the PHS. With all the options they chose, I'm surprised they didn't go with the much cooler rallys.
Cammer-6: "Only TAs got the 1 inch bar". I take it it wasn't available as an option. I've got one I pulled from a 69 T/A subframe -- along with the steering box -- to put on my 400 car. (and this is my 400th post)
Story: Some guy took a real 69 T/A, stripped off the parts and put them on a convertible, so he could have a convertible T/A. Well, he forgot a few parts at the salvage yard...
  #85
Old 09-07-2011, 05:58 PM
FASTASSBIRD FASTASSBIRD is offline
Story: Some guy took a real 69 T/A, stripped off the parts and put them on a convertible, so he could have a convertible T/A. Well, he forgot a few parts at the salvage yard...[/QUOTE]
You could order em over the counter (I know of a couple on first gen camaro's that way) but not as an option on any other f-body. functional, if you need to sell that box haha drop me a pm, my Trans Am has just a base power steering box right now
  #86
Old 09-21-2011, 01:16 PM
Even though the engine seems to be running great, as part of the restoration it will be coming out very soon. Was wondering what you guys thought about rebuilding it? My plans are to tear it down (taking many pics during the process) and simply hone it, get the block and parts dipped for cleaning, re-ring it with cast rings, new timing chain, new bearings and put it back together with all the original parts. I just want to keep this as original as possible with a slight freshening up. Engine currently has 82k.
Is the cam in a Ram Air III installed straight up?
  #87
Old 09-21-2011, 04:05 PM
1969 Ram Air 1969 Ram Air is offline
I would replace the pistons if you are going to take the engine apart. Even though the mileage isn't high, the pistons are 32 years old. They aren't too expensive and maybe you'll save yourself another rebuild job later.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
  #88
Old 09-21-2011, 08:55 PM
I don't think you'll know whether you can get away with only a hone until you tear it down and inspect/measure.
  #89
Old 09-21-2011, 10:39 PM
I agree. Just checked the compression and all the cylinders are at 175-180 which is good. As long as there is no more than 5 thousandths taper I think I'll just hone so that everything is as original as possible. I will also need to get some hardened valve seats for the unleaded gas.
The reason for wanting to just hone is I have been reading that collectors would rather have a not so perfect original car than a perfectly restored car that looks original but it's not.
  #90
Old 09-22-2011, 07:38 AM
74SDformula's Avatar
74SDformula 74SDformula is offline
I am with keith k. I think you need to see what you are dealing with first. Also you have to ask yourself how much you are actually going to drive this vehicle. However I like your idea as far as not getting carried away with the "rebuild". As far as the hardened seats are concerned I would only have them installed if there is evidence of valve seat recession.
  #91
Old 09-22-2011, 09:28 AM
muscle_collector's Avatar
i wouldnt tear it apart at all if it is running good. only original once. clean the thing as good as it gets and enjoy it.
  #92
Old 09-22-2011, 10:22 AM
What M/C said. Reseal it, check the bearings, possibly roll a set in it with an oil pump and drive it.
I wouldn't fool with the hardened seats unless the heads are worn already. Too much of a chance of getting into a cooling passage when cutting the head for them. The Pontiac Olds, and Caddy's have high nickle content which make them wear longer. Chevies are the ones that NEED it the first time around.
Mike
former." --Albert Einstein
- Winston Churchill
  #93
Old 09-22-2011, 08:10 PM
run low lead av gas and some additive and youll be fine on the valves
  #94
Old 09-23-2011, 04:24 PM
What is AV gas? Remember I'm in California and our gas sucks to begin with.
I like the idea of just cleaning it up and driving keeping it 100% original. If it runs good why screw with it I guess? Anyways will wait to see how it drives when I get the new clutch in it before making any decisions.
  #95
Old 09-23-2011, 05:43 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
aviation fuel. buy it at the airport
  #96
Old 11-03-2011, 10:29 AM
brut4s's Avatar
brut4s brut4s is offline
Updates?
  #97
Old 11-09-2011, 01:59 AM
Here are some pics of work that has been done. Everything has been sandblasted and repainted using all the original parts. The engine got new bearings, gaskets and a valve job. The heads were in pretty rough shape.
ID:	262881   Click image for larger version
ID:	262882   Click image for larger version
ID:	262883   Click image for larger version
ID:	262884   Click image for larger version
  #98
Old 11-09-2011, 07:26 AM
Big Moe Big Moe is offline
Looks Great!
  #99
Old 11-09-2011, 08:17 AM
The Boss's Avatar
The Boss The Boss is offline
Wow!
And go racin' in the street.
  #100
Old 11-09-2011, 08:54 PM
You're really moving fast on this one. Nice-
