Old 06-03-2024, 01:45 PM
Default air filter...74 TA
What are y'all using for an air filter?
The local parts store is listing one that is way too tall for my shaker and the one in there is a puralator brand. Even that one the carb bolt thingy barely threads...
74 TA, auto Y code 455, qjet, iron intake
Old 06-03-2024, 02:44 PM
chuckies76ta's Avatar
Airaid makes some nice filters. I like there SYNTHAMAX Dry 100% synthetic, non-oiled filters. I use this one 801-452. but they don't make it anymore. It gives me more room to install the shaker. Made in USA.
https://www.summitracing.com/parts/aid-801-452
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
Old 06-03-2024, 04:24 PM
So it doesn't need the k&n type oil? How do you clean it or is it disposable like the paper?
Old 06-03-2024, 04:57 PM
Held for Ransom's Avatar
AC Delco A366C. Or WIX 42102.
So long, farewell.
Old 06-05-2024, 09:31 AM
No oil. I hate oil bath filters. Wash out with filter cleaner and let dry.
Old 06-05-2024, 12:10 PM
Interesting.
I used to run K&N but the one listed doesn't fit neither.
I found the Wix one on amazon but I'll try to return this dang fram first. Maybe the previous owner mucked with the base or something.
Old 06-05-2024, 12:47 PM
formula kid formula kid is offline
A366C is the correct air cleaner for 1974 Trans am.
Old 06-05-2024, 03:40 PM
unruhjonny's Avatar
IIRC the TA one is in essence a slightly shorter one than the other 4bbl filters - what you likely have is the non-TA filter.
You should be able to cross reference the OEM Delco filter against others to find the correct (dimensional) one for your car.
1970 Formula 400
Old 06-05-2024, 05:09 PM
Yes, a Fram CA136 is a replacement for the Delco A212CW. A Fram CA342 is the so called replacement for the Delco A366C.
So long, farewell.
Old 06-05-2024, 05:25 PM
Oh ok, they gave me the CA136.
I'll check see if they stock that other one when I return this one.
Thanks fellas.
Old 06-05-2024, 11:14 PM
SD73's Avatar
SD73 SD73 is offline
If you're looking for the absolute biggest K&N filter you can fit under a shaker you can use their part number E-1570 . If you want to use paper filter you could try your luck and ask for something that fits a 1969 MERCURY Cougar Boss 302.
