Old 05-28-2024, 10:41 AM
I image they would have had to run a batch of different distributors for the HEI. Being a low production car, probably didn't make cents? (sense)
(also, the SD used a bigger hole for the distributor)
Old 07-09-2024, 08:53 AM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default Rear License plate bracket install?
Is there anyway to install the rear bracket with out first removing the bumper?
Looks like u would have to be a contortionist!
1970 T/A
Old 07-09-2024, 02:47 PM
dpoltzer's Avatar
Default Got it
I loosened all of the bumper nuts and pulled the unit away from the body just enough to get the license plate bracket screws installed. Dave
1970 T/A
Old 07-10-2024, 01:09 PM
nice...the paint is cracking on mine (again) and I'm not looking forward to taking those off if I ever find donors
Old 07-10-2024, 04:57 PM
dpoltzer's Avatar
Default Bumper in Alabama
Not sure where you reside King, but one of our members in Talladega, AL has one for sale. Look in the Firebird Parts For Sale area. Dave
1970 T/A
Old 07-10-2024, 11:32 PM
I'm way up north unfortunately...
It's only cosmetic and not dire yet however this parts car just popped up today coincidently...may check it out
Old 08-03-2024, 10:07 PM
dpoltzer's Avatar
Default Ground strap ??
There is a ground strap screwed in to the floor pan under car on passenger side towards firewall but I am unsure where the other end is supposed to go? It looks like it might go under a bolt that secures the tranny to the block but this seems redundant since there is already a ground strap that goes from back of the passenger side cylinder head to the firewall. Could the ground strap in question go to the sub frame and if so, where? Thx.
1970 T/A
Old 08-09-2024, 08:36 PM
dpoltzer's Avatar
Default Take a look please?
Can one of you with a 74 take a look for where the strap goes? Thanks much.
1970 T/A
Old 08-09-2024, 09:05 PM
Held for Ransom's Avatar
They actually called it a redundant ground cable.
If you have the '74 Assembly Manual, sheet 12H-50 shows it mounts on the lower bolt of the transmission to engine, passenger side.
So long, farewell.
Old 08-10-2024, 06:47 AM
dpoltzer's Avatar
Default Perfect
Thx much HFR. Dave
1970 T/A
Thread Tools
Display Modes
