Trans line placement
Do the trans lines lay between the motor mount and the fuel lines or do they lay between the motor mount and the oil pan I forgot to take a picture when I took the old ones out had the motor in already and couldn’t get them in so now I yank the motor again
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
The trans lines are on the RH side, run up just below the upper control arm. Fuel line on other side. Or are you talking about something else?
Thread Tools | |
Display Modes | |
