Old 06-18-2024, 10:23 PM
Default Air Cleaner history...
Hi fellas:
I have another thread going to track down a 70's carb as Cliff told me the carb that came with the car is of a cheby variety. I also have a vacuum leak so it seemed like a good time to rebuild or replace it anyways.
Anyway, he mentioned that the pontiac qjet is a different beast with the hoses on the other side and some kind of vent on the front.
He also mentioned that a 75 or later would have a larger oriface so I was wondering if whoever stuck the cheby carb in there butchered or made his own shaker base (that I have today) so maybe the pontiac q-jet won't fit it?
Can you tell by the pictures if I have the proper shaker base or will run into problems or should I start looking for a different base?
Thanks!
Old 06-18-2024, 10:25 PM
Photos hopefully rite side upClick image for larger version
ID:	635577Click image for larger version
ID:	635578Click image for larger version
Sent from my Surface Duo using Tapatalk
Old 06-19-2024, 09:37 AM
Aircleaner base is correct 1 1/2" drop for your '74. Shaker top came from '74 GTO but is dimensionally the same as '73-76 T/A, have several of each style.
For a Qjet, unless you've changed to an earlier intake like a '72, or '71 & earlier intake & matching ex crossover heads, I'd prob go with a '77-80 800 cfm Pontiac Qjet to rework Am not a big fan of the early integral choke 750 cfm Qjets like the 7043262, 7043262, the latter being what came on your '74. They can be gone through & reworked though.
Old 06-19-2024, 10:50 AM
unruhjonny's Avatar
it looks like a plug was added to the base;
1971-1979 Pontiac Quadrajets all have a "chimney" fuel bowl vent that protrudes into the air cleaner;
Chev carbs don't have this - which is probably why that plug was placed there.
1975+ Pontiac Quadrajets do have the "chimney" in a different spot than the 71-74 units - so a 1973-1974 air cleaner base might be best matched to a pre-1975 Quadrajet (otherwise your valve cover breather tube won't reach the hook up spot).
Something worth mentioning is that 1973-79(?) Pontiac Quadrajets can change from a heat sink style choke to an electric choke;
You just swap the element, and cap off the feed line.
1970 Formula 400
Old 06-19-2024, 04:13 PM
Oh interesting...50 years of hijinx gets me to this point I guess 😞
I'm not sure what intake I have but it's a 74 SR block with an iron stock one.
I've never had a working choke on any pontiac so that would be a huge upgrade.
Old 06-19-2024, 04:15 PM
So in your opinion would the '75 & up carb chimney fit in that hole that is plugged and other than re-routing the lines I should be good in regards to the base?
Old 06-19-2024, 07:06 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Pictured are the 2 different styles of "chimney vents". The 71-74 style is cast into a removable cover. Through '72 they have a divorced choke and the 73-74 have an integral hot air choke. The later 75-79 style of "chimney vent" is integrated into the airhorn. There is a 2nd style of 800cfm Pontiac Q-jet that has no "chimney vent". It was mostly used on the 301 engine and is an 800cfm carb. I prefer to use these cores for HP builds due to the lack of the vent.
ID:	635623   Click image for larger version
ID:	635624   Click image for larger version
Old 06-20-2024, 03:36 PM
unruhjonny's Avatar
I might have one of those 301 carbs too!
1970 Formula 400
Old 06-21-2024, 11:34 AM
I think I found a '75 carb one town over...pick it up on tuesday
Then I guess it'll be an OJ situation with the base:
Interesting how many different q-jets and chim-chim-chimineys there are...I had no idea...always learning
Old 06-28-2024, 10:16 AM
Skidmark's Avatar
Skidmark Skidmark is offline
I have a 75 TA and was told that the 75 q jet is a kinda odd ball unit. Cliff doesn't recommend using one if you have access to a 76 and up carb.
I've got the stick version xxx263 getting a 76 stick carb built now. Hoping it will fit my base without modifications.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
Old 06-28-2024, 12:28 PM
great...I have two of them in stock now lol
I'll find out soon enough
Thread Tools
Display Modes
