Old 07-01-2024, 01:10 PM
Default What is this rubber hood insulation piece called?
Mines missing
Thanks Click image for larger version
Sent from my Surface Duo using Tapatalk
Old 07-01-2024, 01:17 PM
SD73's Avatar
SD73 SD73 is offline
That is the the cowl weatherstripping.
Old 07-01-2024, 04:35 PM
redonred81 redonred81 is offline
Default Rubber
Your not missing anything.its a safety for the hood not to go thru windshield in case of accident. No rubber on top of that .
Old 07-01-2024, 04:39 PM
burd's Avatar
burd burd is offline
Looks like you’re missing the lower trim on the glass.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
Unburdened by what has been
Old 07-01-2024, 04:47 PM
Default Rubber
Well there are three little holes there for the feet and the T/A i seen yesterday had it - mines leaking when I wash the car....
Like this or should it be a three piece?
https://www.classicindustries.com/pr...rts/w1500.html
Old 07-01-2024, 09:23 PM
1974 is one piece like the one from classic ind.
Later year use the 3 pieces iirc.
Old 07-02-2024, 01:35 AM
Formula403 Formula403 is offline
70-76 used the 1-piece moulded rubber, 77-81 use the roll cut to length in 3 sections, same as what 79-81 use for front of hood.
The cowl seal is to keep hot enginebay heat from entering the grille for cabin fresh air. It won't seal water, nor does it matter. There's gaps, it rains, and inside the cowl is wet each time anyway. What is Leaking?
He's not referring to the hood stop bolt.
Old 07-02-2024, 09:35 AM
burd's Avatar
The pic is all the way in the corner. Not sure really what he’s asking.
Old 07-02-2024, 11:41 AM
Oh ok...one piece that makes sense then...thx
After I wash her, I eventually get a small puddle of water on the driver side floor under the brake pedal. It doesn't appear right away but hours later and I haven't witnessed the drip.
My insulation is totally missing so I mite as well correct that - didn't even realize it was missing until I looked at that other bird.
Old 07-02-2024, 12:17 PM
It could have a rust pinhole in the floor of the cowl or perhaps running down from kick panel that isn't sealed.
Thread Tools
Display Modes
