Old 08-17-2024, 09:11 PM
Jimbobeast Jimbobeast is offline
Default Hood alignment
The gap on the L side of my hood is larger than the R side. How do I move the hood laterally about 1/8"? There is no further lateral play in the hinge to hood attachment bolts. Also, the rear of the hood needs to come down a bit. Which way do I move the hinge on the fender attachments?
Thanks.
Old 08-17-2024, 09:40 PM
indymanjoe's Avatar
I fought hood issues for a long time. Had them rebuilt and it took me 30 mins to get it aligned for good gaps with the back of the hood sitting flush with the fenders.
this is who i used and am very happy with the outcome
https://www.hoodhingerepair.com/
Old 08-17-2024, 10:34 PM
400 4spd.'s Avatar
There are a few ways to deal with those issues, but I'm not up to typing it in detail tonight. If you want to PM me with a phone number I can tell you what you can do.
Old 08-18-2024, 08:08 AM
PontiacHO PontiacHO is offline
I see that you are in eastern NC. I would appreciate your expertise in aligning my 68 Firebird hood. It stays too high next to the cowl. Thanks. Jim. Wake Forest NC.
Old 08-18-2024, 10:50 AM
MUSLCAH MUSLCAH is offline
Put 2 hands on the side of the hood ..near the hinge area...and firmly push the hood to the wider side.
Providing that your fenders are evenly fit to the doors.
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 08-18-2024, 01:09 PM
That's too logical and easy, so it can't work, right? I'll do it.
Old 08-20-2024, 09:41 PM
Well.........how’d yah make out ....?
Old 08-21-2024, 02:35 PM
I pushed the hood near the hinge attachment, then I pushed it again. The side gaps are now perfect. So simple. I'm going to lower the front hinge to fender bolts and see if the back comes dow the remaining 1/2 inch.
Old 08-21-2024, 10:21 PM
To suck that hood down in the rear...
Loosen the rear bolt on the hinge ( where is screws into the fender ) and while the hood is open ...PUSH UP on the front edge of the hood a little...and that will drop the rear of the hinge down.....getting you to where you want to go.
Maybe scribe the bolt and washer or mark it how Evah you want....so that you can see how much it moved.
The Following 2 Users Say Thank You to MUSLCAH For This Useful Post:
Old 08-22-2024, 06:11 AM
Kenth's Avatar
Kenth Kenth is offline
From the 1966 Tempest Shop Manual:
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Thread Tools
Display Modes
